Topic: Homepage Error  (Read 3743 times)
Homepage Error
« on: July 05, 2007, 11:12:28 PM »
Russ,  I see the header and footer for the homepage, but the body is the following text "Couldn't connect to mysql server: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (11)" . . . is this a server problem or a problem on my end?
Homepage Error
« Reply #1 on: July 05, 2007, 11:35:16 PM »
Looks like the MySQL server was down or something when the homepage content was generated. Everything seems to be working now, so I re-generated it manually.
Homepage Error
« Reply #2 on: July 06, 2007, 05:52:59 PM »
Yep, it works fine now!   8)   :thumbs-up:
