Topic: Volvo 940 super mpg mobile  (Read 41918 times)
« Reply #165 on: October 08, 2012, 07:51:29 PM »
Ok,  Added a Kammback  to cookie pan.,  somebody stop me
« Reply #166 on: October 14, 2012, 08:34:35 PM »
 ;D
« Reply #167 on: November 18, 2012, 03:04:03 PM »
I added some sides to the cookie pan spoiler.  SC
« Reply #168 on: November 18, 2012, 05:13:14 PM »
You are slowly morphing the car into the bat mobile....
« Reply #169 on: November 24, 2012, 03:16:37 PM »
Rolling with some Dollar store party platter aerodynamic hubcaps
« Reply #170 on: November 24, 2012, 04:32:46 PM »
Bringing back the moon hub caps
« Reply #171 on: November 25, 2012, 05:14:32 PM »
I'm messing with EGR today.  I hooked the egr valve to the manifold head.  That means Im mixin exhaust gas with the fresh air 100% of the time.   I think that will make me run leaner.  The solinoid that triggers the EGR is hooked to my vacuum gage.  so I can determine if it is working  or when the cpu decides to squirt some exhaust gas into the throttle body.   LEt me know if this is a bad idea..  SC
« Reply #172 on: November 26, 2012, 11:29:27 AM »
It hasn't stopped you in the past, why start now...
« Reply #173 on: November 26, 2012, 01:58:42 PM »
This is true and while you are fiddling with that, throw some pie dough in the new hub caps then drive around dragging the brakes to get them hot . WOW !!  free pie crust  ???
« Reply #174 on: November 26, 2012, 06:22:56 PM »
Ok.. day one,   Full time Egr on.  I have the vacuum gage hooked to the soleniod that opens a vacuum to pull the EGR open.  and the Egr valve  is hooked to a full time vacuum.  Sooo,,  I think it is on / open  all the time.    When I start the car cold, the egr soleniod  opens and the vacuum gage goes up and  down  when I accelerate and off when I  idle. This seems like it should work.
 after about 60 seconds the vacuum gage  goes to zero.  and stays there for the whole trip.   This is weird  so I figure my EGR computer is broke.  The egr gas is fed into the air filter  so it gets mixed real good with fresh air.  Engine is a little rough at idle but not real bad.  On the road it might be running stronger but it is not worse.  SC
