Topic: Volvo 940 super mpg mobile  (Read 41607 times)
« Reply #75 on: July 09, 2012, 10:08:04 PM »
Dude, it's an old Volvo.  The gas mileage is going to suck since it's a box on wheels with aerodynamics that are only slightly better than a city bus.  Put the belts back on it, turn the A/C on and go buy a Geo Metro if seeing high MPG numbers makes you giggle like a schoolgirl.
Dubtech, the more I read your posts - the more I relate to you.
LOL.
My old '92 240 wagon got 32 mpg on the ROAD
« Reply #76 on: July 09, 2012, 10:56:35 PM »
SC . . . you need to back up to whatever set-up you had back in late May . . . you were getting 27 MPG back then!
Part of your problem here is the car is too modern.  It was designed to monitor it's environment and what the driver was demanding . . . and process that info into the best possible settings for the fuel/air mixture and timing.  You start tweeking and screwing with stuff on it and it gets all kinds of mixed signals.  It gets confused and don't know what the heck to do.
Get a older "dumb" vehicle.  They are not programmed to think.  Therefore, they CAN be outsmarted.
Once again, I offer my S-10 as evidence.  According to the official government web site for milage estimates ( http://www.fueleconomy.gov ) my particular truck with a 2.8 and a 5 speed manual should get 16 City, 19 Combined, and 23 Highway.  I regularly get 22 to 23 combined and have hit as high as 32 on the interstate.  And this is MY truck, which means it's got and extra half tone of crap in the bed BEFORE I put a load in it or  set my 330 pound butt in the driver's seat.  And it's got over 200,000 miles . . . and it's now got a newer rear under it that is geared a whole lot lower than the original.  And just this morning when I filled up, still got 22 mpg . . . combined city/highway, leaning heavy towards city . . . and part of the small amount of highway milage was pulling a trailer behind it to boot . . . and had both windows rolled down and the tailgate up.
So what miracle of engineering got it up to the 32 mpg level?  Rust.  It sat for a few years before I got it and the inside of the tank rusted.  Rust got in the carb.  Apparently that rust has plugged the secondary's main jet.  So when the progressive 2 barrel's secondary throttle plate starts to open, the fuel mixture gets really lean, really quick.  To keep the thing running, I have to keep my foot off the floor.  It'll still able to run 70 on the interstate, it just takes some extra time to get there.  So, the thing was capable of getting this kind of milage when it left the factory, but none of 'em ever did . . . most people I've talked with never even got to the government's rated levels . . .
You see, the most effective device for improving milage on ANY vehicle rest directly between the driver's ears.  Use that grey matter up there to control your foot correctly and watch the milage increase!  Or, you can rig yours like mine where if you try to make it inefficient it'll just spit and sputter and die.  Or, you can just let your tank rust and hope you get lucky.
« Reply #77 on: July 10, 2012, 01:42:32 AM »
Aww man! I was just thinking yesterday how we could make the braking charge the battery! I was thinking about a bicycle tire that hung a few inches over the ground and mounted just in front of the driver's door or something. Mount it on a pivot arm and rig up cables so that when you push the brake pedal, the bike tire makes contact. Put the pulley on the bicycle tire and hook it up to the alternator. BAM! You now have that fancy recharge while you brake system!
I still vote for the regenerative braking system!
« Reply #78 on: July 10, 2012, 07:47:05 AM »
I vote for the regenerative Brain system. ;) ;D    To many days out in the sun.
« Last Edit: July 10, 2012, 07:49:58 AM by Ret.Bugtech »
« Reply #79 on: July 11, 2012, 06:23:27 PM »
The ABS started acting up in the rain today.  Now the ABS fuse is pulled.  That should regenerate a few amps.  sc
« Reply #80 on: July 11, 2012, 08:46:51 PM »
Pull the bulbs while you are at it! Use hand signals since it will reduce the electric pull!
« Reply #81 on: July 11, 2012, 11:01:03 PM »
He will have to keep the driver's window down at all times .  Power windows you know. Better yet, take a hammer to the driver's window so he won't be tempted to raise it when it rains or when it gets cold and breezy this winter.
« Last Edit: July 11, 2012, 11:05:30 PM by Ret.Bugtech »
« Reply #82 on: July 12, 2012, 02:46:52 AM »
glass is heavy...
« Reply #83 on: July 12, 2012, 08:08:47 AM »
glass is heavy...
Well you know what that means. Knock them all out.
« Reply #84 on: July 12, 2012, 07:36:51 PM »
Konked out at cvs.  again.   There must be an energy vortex located at the cvs in Lafayette.   this vortex rapidly drains batteries of volvos.    so I Made a new jump start friend.  Plugged  the alternator back in.  Vroom.   sc
« Reply #85 on: July 12, 2012, 09:24:40 PM »
I know that this is gonna sound kinda crazy to you, but have you ever thought about putting a toggle switch in line with the exciter wire for the alt?
Then about 5 minutes an hour you could charge the batery and not have to introduce yourself to Guido the battery jumper....
"Bend Over..."
"Hi Ben, My name is Fletch...I mean Smelly Cat."
Offline DieselDoc
  • Chickamauga, GA
    • S&P Automotive
« Reply #86 on: July 13, 2012, 05:40:31 AM »
"Bend Over..."
Hahahahaha
« Reply #87 on: July 13, 2012, 07:58:16 AM »
Well Duh,  Lafayette = "The Triangle".    Solar flare or you could just blame it on Bush.
« Reply #88 on: July 13, 2012, 08:42:13 AM »
you could just blame it on bush.
What do shrubs have to do with this?
« Reply #89 on: July 13, 2012, 07:13:22 PM »
You mean you don't remember the story in the Bible.  Fire is everything including jumper cables, battery in the back seat, broken gas mains and Moses breaking bad on the Mount.
