Topic: Volvo 940 super mpg mobile  (Read 43296 times)
« Reply #45 on: May 27, 2012, 07:10:26 PM »
I was worried with this od solinoid.  Got a o ring at Ace.  Grinded  out a groove on the solinoid.  Got a little c clamp. to hold the part on since I righty tighty ,  When I should have lefty Lucyied.   AND SNAPPED off the bolt on one side .. I can't believed ATF.cost. 4.49.  A quart.  I poured the old ATF back in, except maybe the last 1/4 quart of sludge at bottom..  seems to run great. Shifts into od now.
« Reply #46 on: May 29, 2012, 10:22:00 PM »
How can I fake out the dash lights.   They think the alt is not wprking.   Would hookin a 2nd battery. To the output wire of the alternator work?   Sc
« Reply #47 on: May 29, 2012, 11:22:27 PM »
Wow, just Wow.
He actually did it.
« Reply #48 on: June 02, 2012, 04:48:55 PM »
I just got 22MPG on this tank. This is running  with out alternator. Disappointing..  It includes dragging a disabled Saab 10-12 miles on the stretchy rope.    That may have influenced the results.   My Saab Clutch line fix ..blew
I met a guy at a yard sale today who drove a Prius and was tubing up some Hydrogen to it. (I showed of the super Volvo)  He had the Hydrogen generator on the passenger floor board of his Prius. I told him to visit Maxi Muffler in Lafayette,   so they could show him what happened to their ceiling when their Hydrogen generator blew up in the lobby. I recommended he move the Hydrogen to the outside of the cabin.   SC
« Reply #49 on: June 02, 2012, 10:51:40 PM »
Only in the "Triangle  :o :o
« Reply #50 on: June 02, 2012, 11:44:41 PM »
Most DIY hydrogen generators actually generate gas that is a mixture of 2 hydrogen molecules to one oxygen molecule.  It is an explosion looking for a source of ignition.  The slighest spark will set it off and it will burn with an explosive force.  It's best quality is perhaps that burning it turns it into water.  Adding a little of this gas into an internal combustion engine can have a significant effect on it's effeciency (IF it's done right, which it usually isn't) . . . but it's kind'a like Germany's Zeplins of the 1930's.  It's all good 'till that stray static spark sets off the gas.  What's REALLY scary is seeing folks who don't have a clue build a hydrogen generator in a glass jar.   :o
« Reply #51 on: June 16, 2012, 12:24:24 PM »
Update!,  Drove the VSMPGM  for 2 weeks with out the alternator.   I can got 60 miles before the electronics  start wigging out due to low voltage.  I have conked out under the CVS drive thru,  at the Dr Office on 136 and  at the the Pre-K school on 151.
 I put the belt back  on the Alternator since this test is over and I am tired of hooking up a charger every day.   Filled up the tank .  Running without the Alt made no difference.  I got 25 MPG with and 25 MPG without.  One guy said that the cars computer goes into an energy saving mode when the battery is not charging and makes the injectors pulse longer to save power.  SC
« Reply #52 on: June 16, 2012, 01:00:45 PM »
Aww man! I was just thinking yesterday how we could make the braking charge the battery! I was thinking about a bicycle tire that hung a few inches over the ground and mounted just in front of the driver's door or something. Mount it on a pivot arm and rig up cables so that when you push the brake pedal, the bike tire makes contact. Put the pulley on the bicycle tire and hook it up to the alternator. BAM! You now have that fancy recharge while you brake system!
I guess its a wash since they get the same mileage
« Reply #53 on: June 16, 2012, 02:34:47 PM »
You need to try this experiment with Stupie . . . that way you have no computers to try to outsmart you.
« Reply #54 on: June 16, 2012, 07:21:13 PM »
^ I bet he doesn't get 60 miles w/o the belt on stupie....
LOL
« Reply #55 on: June 16, 2012, 09:30:03 PM »
Are you sure you were not raised in the Triangle ?
« Reply #56 on: June 16, 2012, 09:39:53 PM »
Heck Far !!!! Linda's V-70 five cyl. Volvo wagon gets 25 mpg up and down Sig. Mtn. everyday with everything connected and no Bat Mobile junk screwed on the car.
« Reply #57 on: June 17, 2012, 07:37:28 AM »
Bugtech ,  Your right about the mpg.  The EPA mpg for the V70 is 25 mpg Hwy
Mine is  24  highway. We both are beating the EPA Hwy mpg rating.
 One thing that may be hurting me is that on these roads around lafayette I dont ever get fast enough to get the torque converter to lock up..  Most of the time the tach is at 2300 at 50 mph.  sometimes things kick in and it drops to 2100 at 50mph
« Reply #58 on: June 17, 2012, 11:31:03 AM »
Wire that up to a toggle switch and lock it down! Just remember to unlock it when you stop or come to a hill....
« Reply #59 on: June 17, 2012, 11:31:52 AM »
nope; we are neighbors, old man!
