Topic: Volvo 940 super mpg mobile  (Read 43297 times)
« Reply #150 on: September 06, 2012, 11:47:00 AM »
Well...you got me there. ;D
« Reply #151 on: September 06, 2012, 07:09:09 PM »
 :D :D :D
« Reply #152 on: September 23, 2012, 03:04:57 PM »
I made me a cookie pan spoiler today.  it has rounded edges for safety  and it smells like aluminum cookies
« Reply #153 on: September 23, 2012, 05:57:41 PM »
" FAIL".
« Reply #154 on: September 24, 2012, 08:51:42 AM »
Just think, A dozen Cookies by lunch time while parked in the sun at work. Munches on the way home. Yum Yum. ;D
« Reply #155 on: September 24, 2012, 10:42:45 AM »
Saw an ad on Craigslist about hydrogen injection? Supposed to double your has milage
« Reply #156 on: September 24, 2012, 11:10:00 AM »
I can see it now, A 940 Volvo "Hindenburg Model" :o :o
« Reply #157 on: September 24, 2012, 11:28:53 AM »
Hydrogen systems actually work . . . but hydrogen can be dangerous stuff!  A little hydrogen and spark = a powerfull explosion.  The good news is, it's a clean explosion.  When hydrogen burns, it creates water.
Joy's uncle installed a hydrogen generator on his Toyota pickup.  He has an amp gauge on it . . . it draws about 15 amps when it's running.  It bumped up his milage about 3-4 mpg.  But, he forgot to turn it off when he turned his truck off one day and several minutes later he had a small exposion.  It blew the cap off the water tank for the hydrogen system off and put a dent in his hood and busted a plastic box on his intake system (between the air flow sensor and intake manifold).  I need to find him a relay and wire it in so it turns off with the switch before he blows the truck or himself up.   8)
« Reply #158 on: September 24, 2012, 02:57:07 PM »
and if you burn magnesium... and then throw water (or beer that tastes like water) on to the magnesium fire, you can super heat the water and separate it into Hydrogen and Oxygen. The Oxygen joins up with the Magnesium... but that hydrogen...that hydrogen goes KAAAA BOOOOOM!!!! Its a clean burn alright...right through everything you own. I still have a step bumper and a set of useless folding chairs to prove it. The case savers hurt a little bit
« Reply #159 on: September 24, 2012, 07:30:23 PM »
I really think I m gonna get mpg now.  The Volvo even drives better since. I have the same size tires on the back.  I pulled the speedo out this weekend.   Plugged in the solder iron.  Reheated the solder joints.   So far I think the speedo is fixed and the odometer.  Sc
« Reply #160 on: September 24, 2012, 08:12:35 PM »
you were doing all of these tests without an accurate way to track you mpg? That's brilliant!
« Reply #161 on: September 24, 2012, 08:27:50 PM »
Thx Bignick.Since the odometer goes in and out ,  ive been recording that ,  then adding 50 to 100 miles so I show improvement/  Last tanks was 24.5 mpg
« Reply #162 on: September 24, 2012, 09:04:15 PM »
I try to add 150-200. It really helps with my mileage.
« Reply #163 on: September 24, 2012, 09:05:52 PM »
Neat! I'm getting almost double your mileage. Imagine if I put a cookie sheet on my car!
« Reply #164 on: September 24, 2012, 10:01:44 PM »
I think SC is on to something with the cookie sheets!  If I put my cookie sheets on my truck, I wouldn't have anything to bake cookies on . . . with less fresh baked cookies around to eat, I'd loose weight . . . with less weight to carry, my truck's milage would increase.   8)
