Topic: Volvo 940 super mpg mobile  (Read 43297 times)
« Reply #135 on: August 18, 2012, 07:56:26 PM »
Opps .  meant to tell a story.  I see
this Baloo statue on craigslist.  And I
wanted it.  Bad!     Some Grandma beat
me to it.  I was bummed out.   But the
Jungle book Gods favored me.  I texted
the guy and he said.  " Baloo was still
there waiting for Me!".   Its the
middle of the week and  I'm working and
doing important stuff.  BOOM!.  I get
my chance to score the  Jungle Book
Bear  Thursday evening.    I take
Margaret and her Mom  out to get "My
Bear" .   Turns out Baloo  was only
half a bear and the rest was tree
stump. 500+ lbs of wood. You would
think an exhausted teacher and and a
Grandma could help load Baloo in the
van,  but no.  Jeez...   Crest fallen,
I scamper on home and text the guy.
"Can you cut ole Baloo off the stump".
He says "sure".   "Yippee"  I squeal in
delight.   Saturday and I'm at
Pearsonality  Chainsaw carving,  Seems
he is  giving  his older carvings that
are little worse for wear to good
homes. There was a lot other great
carvings but  I am more of the worse
for wear wood carving collector.  We,
(I mean he) cuts Baloo of the  base and
he gives me these other cool bear
totems and things. We have a good time
talking.. I show off the super Volvo.
...Which he thinks is cool...   So
there you have it.   Great Day for  Me
and Baloo.  Mike   8-18-12
« Reply #136 on: August 25, 2012, 10:27:20 AM »
Update on new rims and tires.  They don't fit in the front.  Son OF a Bisquit!.  Maybe I can get some spacers for the lug bolts?  IS that something anyone has heard of.  SC
« Reply #137 on: August 25, 2012, 10:45:38 AM »
Did not someone tell you about this awhile back ?  I have heard about spacers. I think it was a wrecker service and a Paramedic  that told me.  Its your coal truck. ;D
« Reply #138 on: August 25, 2012, 12:29:44 PM »
My Baja had 1" spacers on the fronts to keep the NDTs from rubbing. I only had one wheel fall off and that was on the back with no spacers. Lots of people use spacers, lots of people would never consider it. I would be cautious on a vehicle I drive pretty often. The Baja was MY coal truck, but I rarely drove it and if I did, it wasn't far.
« Reply #139 on: August 25, 2012, 05:41:16 PM »
Spacers are just fine if you use correct built ones,  the off road guys run them all the time with no problem, you bolt them to the hub then bolt you wheel to them,  they will prob cost more than you have In the rim
« Reply #140 on: August 25, 2012, 10:21:49 PM »
The ones I had were just 1" thick pieces of aluminum with holes drilled. I had to find longer bolts but it worked
« Reply #141 on: August 25, 2012, 10:25:17 PM »
I have 10mm spacers on the rear wheels of the Audi to push the wheel out slightly, so they don't "tuck" as much since it's lowered.
« Reply #142 on: August 25, 2012, 11:42:05 PM »
Volvos have studs with lug nuts. They don't have a lot of extra length .
« Reply #143 on: August 26, 2012, 10:45:58 AM »
That's gonna make spacers difficult if not impossible then. On VW/Audi, all you gotta do is get longer lug bolts.
« Reply #144 on: August 26, 2012, 12:55:27 PM »
I was thinking of adapters, a lot of times that is what you need to put different wheels
« Reply #145 on: September 03, 2012, 11:43:53 AM »
I bet you thought i could not  make the classic volvo look worse.  Of course you were incorrect sir!    Solar panel on the roof.  Ahh  HA Ha AH !  Its Alive!!!!  SC
« Reply #146 on: September 03, 2012, 11:51:49 AM »
A while back I said you got lots of flat roof up there, cover it with solar panels!  Glad to see you finally starting listen!   ;)  But, only one panel?  ???
« Reply #147 on: September 03, 2012, 08:32:02 PM »
Eh, I already had you beat on the solar panel.
« Reply #148 on: September 04, 2012, 05:41:16 PM »
Did you rescue that panel from the garbage can behind the Solendra(?) plant ??  ;D ;D
« Reply #149 on: September 06, 2012, 06:38:10 AM »
Maybe... but your solar panel hasn't been expertly installed with bungee cords and tape...
Jealous....
 :D :D
