Topic: Finally Got One! Wooo Hooo!!!  (Read 60248 times)
Re: Finally Got One! Wooo Hooo!!!
« Reply #150 on: July 09, 2013, 11:42:10 PM »
Now you're using a Dasher to make ice cream? What a great idea!
NOT this Dasher:
« Reply #151 on: July 09, 2013, 11:51:37 PM »
Here's my accumlation of various ice cream freezer parts.  The green bucket is in better shape than the blue one, but I can't find a canister to fit it.  I can't find a crank that will lock down to the blue bucket.  I can see a trend here . . . This is how I started trying to put ONE VW Beetle together for Justin 17 or 18 years ago.  I ended up with over 20 VWs in my back yard at one point . . . and never had more than two on the road at any given time.
« Reply #152 on: July 10, 2013, 04:00:24 PM »
oooohhh look!!! one that almost runs! Just needs to be rebuilt! I have two of 'em!
http://www.ebay.com/itm/Late-1920S-Early-30S-Johnson-Utilimotor-/290943526987?pt=LH_DefaultDomain_0&hash=item43bd95e84b
« Reply #153 on: July 10, 2013, 04:39:06 PM »
Thats funny Russ ;D ;D   I just wonder how many quarts of Castrolcream it could produce. Just think,It would be the only ice cream maker in the world that could blow a head gasket. :o :o
« Reply #154 on: July 10, 2013, 10:38:03 PM »
I've found about 8 of them that still exist . . . including the two you own.  And thought Maytags were rare!   :o  You need to get yours running!
« Reply #155 on: September 15, 2013, 11:59:56 PM »
My Maytag was priced at $160. Guess that was a bargin.  A twin cylinder Maytag just sold on eBay for almost $1,500!   :o
It wasn't a washing machine motor, it was a running a small generator.  I think Maytag made these for the military during WWII, and they are pretty rare . . . but it's still a twin cylinder Maytag.  As a generator, it's not going to power much more than a few lights.  $1,500 is crazy!!!
« Reply #156 on: September 16, 2013, 06:05:40 AM »
Saw these at the McMinnville fair
« Reply #157 on: September 16, 2013, 10:55:46 AM »
that trailer looks way over loaded!!!
« Reply #158 on: September 16, 2013, 04:15:08 PM »
Can't be overloaded . . . it's only got about 20 HP worth of engines on it!
« Reply #159 on: September 16, 2013, 04:24:50 PM »
I think that IS a very rare piece. I've seen a ton of Maytags but never one of theses
« Reply #160 on: September 25, 2013, 10:54:43 PM »
I ran a couple of tanks of gas through my Maytag at Swap-A-Paluza, and with the help of William, Randal and Chuck, I got my White Mountain Ice Cream Freezer in working order.  To make it look pretty, I still need to strip the old paint off the wood bucket and repaint it (I have a feeling one or two layers of the paint may be lead based), and weld up and install the lower replacement ring we made (the original had rusted away).
Now I just have to figure out how to hook the two of them together.  The Maytag is supposed to run about 1050 RPM.  I'm guessing I need to run the freezer at about 30 RPM.  If I did the math right, that's about 35:1.  Anybody have a small 35:1 speed reduction gearbox laying around?   8)
« Reply #161 on: September 26, 2013, 11:10:41 AM »
Call Motion Industries.
Bill Cleghorn
Motion Industries
Account Representative TN70/GA56
Cell 706-271-6322
email bill.cleghorn@motion -ind.com
Bill is my neighbor and services plant SI.
He is there all the time and you will get the Shaw Discount if you buy.
« Reply #162 on: September 26, 2013, 03:03:48 PM »
I can rig something up using a jack shaft.  I can use the small pulley on the engine to drive a big pulley on one side of the jack shaft and have a small pulley on the other side driving a big pulley on the freezer . . . but that requires a lot of math to figure out exactly what size pulleys to use.  A gear box would really simplify things.
But, I've looked at the price of new gear boxes . . . I really doubt that even with the Shaw discount it would make it cheap enough for me to justify buying a new gear box.  I'm hoping to find a used one somewhere.  If that doesn't pan out soon, I'll try Motion.  I kind'a got a feeling I'll end up with two belts, 4 pulleys and a jack shaft.
« Reply #163 on: September 26, 2013, 03:59:14 PM »
Old Fords and Chevys (Think 1950's) had a bolt on overdrive unit.
It was smaller than a shoebox and might be of some help.
Gear reduction box from a splittie?
VW trans? (4 speeds of ice cream perfection...
Just a thought.
« Reply #164 on: September 26, 2013, 04:56:14 PM »
Yeah, use a vw transmission... Just take a stub axle and bolt it to the output cup on an old IRS. Tack weld or slide a pulley onto the end. Then you take a old clutch disc and affix a pulley to it and slip it over the input shaft with a cotterpin to hold it on. Get a buggy shifter kit and you'd be golden!!!
You could have 4 speeds plus a few extra clutch discs with extra pulleys affixed for more variation.
or, you could find the cone pulleys from the top of a drill press and make those work!
