Topic: wt of oil  (Read 3129 times)
Offline eakanator
  • Rome, Ga
wt of oil
« on: January 14, 2011, 02:00:07 PM »
What multi-weight do you use?  10-40 15-40  20-50?
Tried searching, but seen only on topic where a straight 30wt was used. Want to change oil this weekend and wasn't sure how heavy or light to go with the air cooled engine.  I was thinking due to winter maybe a 15-40.  then summer maybe a 20-50
thanks
ron
Offline eakanator
  • Rome, Ga
Re: wt of oil
« Reply #1 on: January 14, 2011, 02:14:48 PM »
Searched with oil and didn't find but just one subject. Went back and searched again with the word "Castrol" and several topics popped up. Looks like the engine likes a 20w50?
thanks
ron
Re: wt of oil
« Reply #2 on: January 14, 2011, 02:37:21 PM »
20-50 . NO 10w unless the temps are really cold and stays that way. like zero
Offline eakanator
  • Rome, Ga
Re: wt of oil
« Reply #3 on: January 14, 2011, 08:09:20 PM »
thanks dave.
Re: wt of oil
« Reply #4 on: January 15, 2011, 11:25:42 AM »
I used 30 wt. for years with no real problems until I started up my Beetle one day at work when it was about 5 degrees and pulled on to Hwy. 27 about 10 seconds later.  I blew out two quarts of oil in the 13 miles between work and home.  When I stopped to add oil, it took forever.  At near 0, 30 wt flows about like peanut butter!  After the weather warmed up, I cleaned all the oil off the engine and tried to find the leak, figuring it was the oil cooler . . . but there were no leaks.  Ever since then I've been taking David's advice and running 20-50.
