Topic: Vin # lookup  (Read 2280 times)
Offline HowieDoin
  • Fort Oglethorpe, Ga
Vin # lookup
« on: July 25, 2010, 04:05:31 PM »
Hello,
Where would I go to look up my vin#?
#239209409
I'd like to find out where she was born.
Thanks in advance
Scott
Re: Vin # lookup
« Reply #1 on: July 25, 2010, 06:53:13 PM »
Check out the Technical section on the Samba....
A link....
http://www.thesamba.com/vw/archives/info/chassisdating.php
Then fish around in there for a bit, get the M-code plate info, that often gives you port information for the importer.  There's also info on their about obtaining your "Birth Certificate" for your ride as well.
Re: Vin # lookup
« Reply #2 on: July 25, 2010, 11:39:38 PM »
She was born in Germany ;)
You will uncover a lot of info from the M-plate. On a '69, it's on the metal wall behind the driver's seat. Snap a photo of it or write the codes down in the order that they appear and reference the numbers here: http://www.type2.com/m-codes/
Or post it for me, I have a book with them and can probably decode most of them for you. It'll tell you exactly how the bus was configured from the factory.
Offline HowieDoin
Re: Vin # lookup
« Reply #3 on: July 26, 2010, 07:39:09 PM »
Thank You Gentlemen.
With your direction I was able to find these.
I appreciate your help.
Scott
« Last Edit: July 26, 2010, 07:52:07 PM by Russ »
Re: Vin # lookup
« Reply #4 on: July 26, 2010, 07:53:19 PM »
How about that. It was picked up by the first owner at the factory in Wolfsburg.
Re: Vin # lookup
« Reply #5 on: August 06, 2010, 01:22:55 PM »
I think the buses were being made in Hanover by then, but feel free to fact-check that. ;)
