Topic: vdo gauges  (Read 2880 times)
Offline eakanator
  • Rome, Ga
vdo gauges
« on: March 22, 2005, 08:20:31 AM »
This may sound goofy, but need to order a new fuel gauge sending unit for the bug.
When looking on the CIP website,  they sell two different gauges, one being a vdo gauge & the other, a non-vdo. Of course the non-vdo is $10 less.
the question, is VDO a brand name or is there something special about a VDO sending unit that I may need to order it instead?
thanks
Ron
vdo gauges
« Reply #1 on: March 22, 2005, 10:16:11 AM »
VDO is the brand name. Most of the time was the orginal "stuff" used.
Offline eakanator
  • Rome, Ga
vdo gauges
« Reply #2 on: March 22, 2005, 01:40:48 PM »
Thanks David,
Just wasn't sure if something about one could have to do with grounding, etc.
Still remember before getting in volkswagens, there was the topic of 6 volt stuff and had to be careful about radios and anything else that you installed.
Thought I'd ask before I regreted something.
vdo gauges
« Reply #3 on: March 22, 2005, 03:33:18 PM »
Ron, Im not sure if your tank unit is bad unless you found something. You  can also check this unit out of the tank using a volt meter, one probe to ground,other to the wire  connector. Move the float up and down and see if the resitance (meter hand ) moves with the float. We had more problems with the gage (dash) than anything else. Sometimes we had to put all 3 pieces in to get the dang thing to work.  Float unit, limiter, gage.
 Stick with good parts !!
Offline eakanator
  • Rome, Ga
vdo gauges
« Reply #4 on: March 23, 2005, 03:21:13 PM »
Well, the first test, where I took the lead off the sending unit at the gas tank and grounded it,  the gas hand went to full then back to empty, so (although don't like to assume), but if the needle on the gauge moved, would that then tell me that the sending unit would be bad?
I wll also try to remove the fuel sending unit and put the volt meter to it and see what happens.
Ron
Offline eakanator
  • Rome, Ga
vdo gauges
« Reply #5 on: March 23, 2005, 03:55:16 PM »
ok, Here I am assuming again, but if the hand on the voltage meter moves, that's going to tell the sending unit is good, right.
If the hand moves when I ground the lead from the sending unit to ground then falls back to empty after ungrounding(which it does), then would the problem be more with the limiter or as CIP calls it a "voltage vibrator"?
Ron
vdo gauges
« Reply #6 on: March 23, 2005, 03:57:03 PM »
These things are goofey sometimes. Where the wiper rubs on the wraped windings, it could have broken wire or the wiper could not be touching in spots, but the dang thing still could work somewhat. Thats why I said we sometimes had to put all 3 parts in .  Go figure.  I have seen the tank sending units melted down into glob do to the voltage limiter shorting out somhow. Thats why I told you about the" blinking light test" on the limiter. If it doesn`t blink, Its bad. You can`t tell by just looking at it.
Offline eakanator
  • Rome, Ga
vdo gauges
« Reply #7 on: March 23, 2005, 04:07:27 PM »
when you say a test light, just a little cheapy with two leads and a bulb?
Put one lead on the connector and one to ground with the switch on? the the bulb should blink?  This is one reason I didn't test the limiter, wasn't sure where to put the other lead and if it was the bulb or a light inside the limiter that should light up?
vdo gauges
« Reply #8 on: March 23, 2005, 04:45:35 PM »
correct on the test light except mine looks like a ice pick wih one lead and the bulb inside. Anyway ground one lead, connect or probe the limiter connecter that pushes on the speedo housing(right side looking in).With the switch on it should blink. You can ck. the other side for power.(push on wire conn)
