Using dual 34/3's on a 1500 SP?
« on: March 04, 2013, 08:29:08 AM »
Been toying with this idea for a 90mm case and sp heads I have to build.
But could use this on the bus.
The Kadron mounts are almost the same spacing as a DP Carb.
I am having some 34's reworked and was thinking about wallowing the kadron holes slightly to mount the 34's on a SP 1600 I have in the bus.
I can get the ball's for the kadron linkage to work on this set up.
Has any one else ever tried this?
I am thinking it will be jetted too rich, but I have an assortment of jets from 28's, 30's, and so forth to try.
The Kadrons are 40's so I am thinking on a stock engine, (1500) this may work great...
Thoughts?
Comments?
Was just thinking outside the box a little...
