Topic: Turtle Lights  (Read 3178 times)
Bohog
Turtle Lights
« on: May 08, 2006, 10:37:51 PM »
Has anyone installed turtle lights (rear lights) on a Bug (73)
they come with no instructions and don't plug in same as original.
The are RCD inovox made in brazil.
I've tried all sorts of combos with the wires and can't get them to work properly.
Turtle Lights
« Reply #1 on: May 09, 2006, 09:43:23 AM »
Sorry , I'm not familiar with them. Where did you get them ?  Do the have the 3 bulb set up like you originals ? :roll:
Bohog
Turtle Lights
« Reply #2 on: May 09, 2006, 05:36:13 PM »
The old 73 had 4 bulbs the new set has 3 mid america has them I bought them a BP8 from one of the vendors. I've wired it as follows red-blinker black and grey- stop blue -back up and brown and they don't work properly.
Turtle Lights
« Reply #3 on: May 10, 2006, 10:39:06 AM »
You are correct on 4 bulb set up . Its been awhile.  I belive all your bulbs in the original tail are single filiment ?   On your new lights ,Is one of the bulbs a double filiment ? if so ,It would be the running tail light plus stoplight wired like a 70 model. Im' sitting here racking my brain trying to remember the color codes. Brown is always Ground !!. As long as you don't have the brown wire hooked to the hot side of something other than the metal (?) housing you should be able to plug any wire to any blub holder and something should light up. You could get a buddy to turn on things, mash the brakes , turn sigs, Rev light (with the switch on) and find out what wire does what with a test light.
Offline sidekick
Turtle Lights
« Reply #4 on: February 28, 2009, 06:45:21 AM »
I have 3 sets of inovox dome  tail lights
 they are easy to wire and look great. I am looking for replacement lenses tho- I cracked one. I cannot find the source here in Michigan.
 the ground is on the cross bar, each light has it's own  spade terminal. You can buy a grommet for the back at most hardware stores. Be sure to silicone it real good or it will short in no time.
Turtle Lights
« Reply #5 on: March 04, 2009, 12:08:43 AM »
do you have a pic of these lights?
Offline sidekick
Turtle Lights
« Reply #6 on: March 04, 2009, 06:39:02 AM »
http://avenger-valkyrie.org/avbbs/viewtopic.php?t=12
http://www.avenger-valkyrie.org/images/sidekick/DSC01150.jpg
 I have these lights in smoke, euro and the one posted just red and clear. Looking for a source to replace the cracked one.
Turtle Lights
« Reply #7 on: March 04, 2009, 08:12:48 AM »
I'm not really in to signing up on forums just to see a pic :( I'll just assume they're something cool and different
