Topic: Tires for my 1973 VW Westfalia  (Read 3708 times)
georgp
« on: March 18, 2008, 12:52:18 PM »
good afternoon,
finally the dry rotting has won.
I have to break down and by some new tires.
From the factory they installed 185/R14 on the van and I am driving 195/R14 right now. Looking around i could not find a lot of places where I could get any reinforced tires and if so they were way too expensive.
My questions would be:
1. Do I need the reinforced/radial type tires at all?
2. If yes where is a good place (other than coker) where I could purchase those?
thanks for the help.
Georg P.
« Reply #1 on: March 18, 2008, 01:13:09 PM »
Yes, you absolutely need reinforced sidewall tires on a bus. Don't settle for anything non-reinforced.
I bought a set of Yokohama Y356s from Tire Rack and they've lasted a really long time.
« Reply #2 on: March 18, 2008, 01:39:42 PM »
I have always had good luck with Continental Vanco-8's which can be purchased at http://www.tirerack.com/tires/tires.jsp?tireMake=Continental&tireModel=Vanco-8
Offline Bumble65
  • Ringgold
« Reply #3 on: March 18, 2008, 01:45:52 PM »
I believe Walmart can also order the Vanco8 tires that Brian posted.
« Reply #4 on: March 18, 2008, 02:25:07 PM »
If I'm not mistaken, Continentals are VW OEM tires, they would be a good choice.
« Reply #5 on: March 18, 2008, 06:35:02 PM »
Quote from: "Russ"
You are correct :thumbs-up:
Offline swagginjello
  • cleveland, tn
    • facebook...
« Reply #6 on: March 18, 2008, 06:36:13 PM »
im gunna put vanco-8s on mine when the time come, unless i find some used ones cheap. dont think they are as good on ice as the Yokohama... not that we get much ice here. just a thought.
« Reply #7 on: March 24, 2008, 08:25:14 PM »
I've had both. The Yokos do wear long and show no signs of dry rot after over 7 years in the weather. However, they're worthless in mud/snow. The Continentals are m/s rated and ride about as well. I didn't have them long enough to say if they wear as well, though. The Yokos look more appropriate for a T-2 bus and the Continentals have a more modern look (if that matters).
