Topic: Super Beetle Gas Gauge - How to fix  (Read 9435 times)
Offline Big Toe
« on: June 25, 2002, 07:01:32 PM »
We have a '74 Super, I changed the gauge, and the sender :confused: and smoked the gauge :cussing:(wired backwards  :blush: ) then I tried a used gauge still no luck. :cussing: Is there any way to check the sender unit, and gauge  :questions:  short of buying a new one. Thanx for any  :help
« Reply #1 on: June 25, 2002, 11:23:18 PM »
You can check the sender with an ohm meter . . . I can't find my Bentley manual, so I have no idea what the reading should be, but it should be low ohms when the float is raised and get progressively more resistance as the float drops.
My experiance has been that the #1 cause of the gauge not working is bad wiring . . . usually just bad connections.  Make sure the sender is grounded!  The little device on the back of the gauge (the "exciter") is (again, in my experiance) the second leading cause of the gauge not working.  Next would be the sender and then the gauge.
But, keep in mind that I'm far from an expert! The truth is I always just swap parts around until I find a combination that works (you can do that when you have a dozen or so parts cars in the back yard) . . . if I get frustrated before I find that combination I usually just go without a gauge for a couple of years, then I'll try to fix it again.  That makes driving more of an adventure anyway.
« Reply #2 on: June 26, 2002, 02:19:12 PM »
:lookaround:  :blush:  :spank:  :oyvey:
Ever here the old saying, "Take my advice; I'm not using it."?
At 8:30 this morning I ran out of gas in my '74 Super Beetle.  No, the gas gauge doesn't work.  It did until I tried to fix the odometer.  The odometer worked for 7/10s of a mile, and the gas gauge didn't work at all after I reinstalled the speedometer . . . that was 3 or 4 years ago and I haven't attempted to fix it yet.
And no, Herb, before you ask, I did not ride the short bus to school with all the other "special" kids . . . they made me walk.  slam
At least this time I did have a gas can in the trunk, so I didn't have to pay $5 for a one gallon can at the Favorite Market.
« Reply #3 on: June 26, 2002, 04:06:59 PM »
I think an easier count to make would be to take a poll of those with WORKING fuel gauges in thier A/C VW's.  My Fastback is the first one I've had that it seems to reliably work (now I've done it....).  I must have fixed the one in my Ghia a few times before giving up on it, and I'm pretty sure the Keedy Ranch up there doesn't have a working gas gauge present.
Seriously.  The Bentley Manual has a very nice description of how to test the gauge.  I'll try to sum up if you don't have one.
fuel guage that never moves from full has a grounded control circuit.  Disconnect the control wire from sending unit, if guage falls trouble is in sending unit, if not control wire is grounded somewhere between sending unit and gauge.
if guage doesn't register at all, remove guage wire from sending unit and ground it, if guage goes to full sending unit is bad or not properly grounded, if guage still doesn't move wire or guage is faulty.
Hope this helps
VWTrav
Offline Big Toe
« Reply #4 on: June 26, 2002, 09:52:48 PM »
Thanx for the insight :3dbigsmile: I think I'm gonna have to hunt up another gauge :questions: since my odometer doesn't work either  :turn:  So far I've run out of gas once :sneaky2:
