Topic: Still More '96 Passat Questions  (Read 6781 times)
« Reply #15 on: May 23, 2009, 09:03:52 AM »
Yeah... the newer clusters you can't even replace a bulb in. I had a tt yesterday that needed a new cluster....$829.00.... :shock:
An old air-cooled car looks better every day. :D
:shock:  :shock:  This makes you want to run out and buy a new Audi maybe even two.  I think a Bug dash light bulb cost maybe 50 cents to a $1.00 ? :roll:  :roll:
« Reply #16 on: May 23, 2009, 10:49:23 AM »
Yeah, this seems like a lot of work and money just to have a good heater and air conditioning.    :roll:  Heat and air is WAY over-rated, but Joy and Franny like it on long trips, so what'cha gonn'a do?   :?
« Reply #17 on: May 23, 2009, 11:47:26 AM »
Quote from: "Zen"
Rent a car.  Linda and rented a brand new 2006 Pontiac and drove to Tucson and back. That dang thing got 32 MPG running 75-80 mph most of the time. Rental cost was about $180.  Cheap enough. The old Volvo was getting a little long in the tooth and I didn't want to scare the poor thing to death.
     If that doesn't work, there is the "Old Grey Dog" but it might take 2 weeks to get to Disney World. :lol:  :lol:
« Reply #18 on: May 23, 2009, 12:15:05 PM »
Rent a car... that's freakin hilarious,,,
« Reply #19 on: May 23, 2009, 05:39:59 PM »
Rent a car . . .  Rental cost was about $180.
I hear ya Rick!  If I pay $180 for a car, I expect to get to drive it at least 6 months . . . and still be able to get my money back for it at the scrap yard!  :D  I gave $300 for the Dasher and drove it for over a year.  I've been driving this S-10 over a year and half and I didn't pay anything for it!  And after a little work, the heat works in both of them . . . and if I wasn't so cheap I could of fixed the air in both of them . . . but then I wouldn't need to keep the Passat.   :idea1:
« Reply #20 on: May 24, 2009, 11:01:27 PM »
#-o Today the Passat developed a new problem . . . the driver's door pops opened for no apparent reason while going down the road.  And,   the door lock won't push down on this door now for some reason.   ](*,)
I had a lot of trouble with this door when I installed a new window regulator and when I installed a new exterior door handle.  Something about the door seems to be out of whack . . . bent or warped or something . . . but I can't figure out what it is.  I think I'll run down to Pull A Part tomorrow and get another door . . . I got some parts off the two they have down there and both driver's doors looked good (someone had already pulled the window regulators, but the doors didn't seem to have any structural damage) . . . but neither one is white.   :?
« Reply #21 on: May 24, 2009, 11:30:10 PM »
Thats OK Zen . neither door on Homer is the same as the body color.
« Reply #22 on: May 25, 2009, 12:19:53 AM »
I've seen some cars with mucked up lock cylinder assemblies where the paddle on the back side of the cylinder gets hung in the "open" lock postion, and it's like you're constantly trying to unlock/ open the door.  Weird stuff, but it's like the electrical part of the latch conflicts with the mechanical latch.
« Reply #23 on: May 25, 2009, 08:13:53 AM »
That sounds exactly what's going on.  I think I've figured out to fix it and everything else that's wrong with it . . . When I go to Pull-A-Part, sell it to them and use the money to buy a Greyhound ticket back home!  The last time I was there they were paying $6.50 per 100 pounds . . . how much does a Passat weigh?
« Reply #24 on: May 25, 2009, 08:49:54 AM »
Carefully pull the door handle out, look inside, see if the index point in the latch is turned left or right, should be straight up and down in the rest position.... try to turn it with a screwdriver, see what it  does, make sure the lock is working right, left unlock, right lock... 8)
« Reply #25 on: May 25, 2009, 07:18:39 PM »
Sounds to me like the door latch may be messed up.  The driver's door can't be locked with the door open, so if the latch is bad you won't be able to lock the door - oh, and the door won't latch either   :D
Before you swap out the entire door, pull the latch off and see if it's working correctly with no outside influences.
« Reply #26 on: May 25, 2009, 08:39:38 PM »
Took it apart and couldn't find anything wrong.  Put it back together and everything worked great!  Yeah!!!   8)   Got the door panel back on and closed the door . . . everything still works!  WOOOO HOOOO!!   :D   Tried the key.  It locks/unlocks like it should . . . even rolls the windows up and down like it should.   :D  8)  :thumbs-up:  =D>   Took the key out and went to get in . . . the door won't open.  It's unlocked, but it won't open.  It worked fine a minute ago.  Used the key and rolled down the window . . . it opens fine from the inside.  Closed the door and tried it again . . . locks and unlocks like it should with the lock button and the key, but the outside door handle won't open it unless you hold the key in the unlock position.   ](*,)  ](*,)  #-o  ](*,)   Started taking it apart again and it appears that something on the door handle is broken . . . the handle is new . . . well, almost new.  Just put it on back around Christmas when I did the timing belt.  Do all Passats from this era have the power windows and door locks?  If I could pull all this crap out and go to manual locks and windows, I'd do it in a heartbeat!  I'm just about ready to dump it and put a head gasket on the Dasher.
« Reply #27 on: June 14, 2009, 02:46:05 PM »
I got a box of German parts from Autohaus last weekend, but I was in Stevenson.  I had a family reunion yesterday, so I just now got around to bolting on some new stuff.
The 6 month old door handle had a roll pin backed out and the lever that works the latch was just flopping around.  I fixed the old handle, but put the new one on it anyway.  Door problems solved!  . . .  at least for now . . .
I put in the proper pressure sending unit at the oil cooler/filter flange and replaced the Bosch oli filter with a Mahle fliter . . . I can rev it to 2500 rpms and hold it and the oil light/beeper doesn't come on!  I drove to Red Top Mtn. State Park yesterday and it was pain in the rear . . . If I got over 2000 rpms for just a few seconds, the light and beeper would come on.  The only way to stop it was to turn the engine off.  It wouldn't have been that bad, but it hits 2000 rpms between 65 and 70 and most of the trip was on the interstate . . . and the cruise control doesn't work.
All I've got left to do now is fix the cruise control and get the radio out of the SAFE mode . . . and figure out which wheel bearing is starting to roar . . .
I keep telling myself this is a good car and we got a great deal on it . . . but I'm starting to think I'm lying to myself about both of those things.   :oops:
« Reply #28 on: June 15, 2009, 07:38:39 AM »
Amen !!
« Reply #29 on: June 15, 2009, 04:03:40 PM »
Let's see . . . I've owned it two years.  I started out right off the bat putting plugs, wires, distributor cap and rotor on it.  Took the trunk lock apart and made a key to fit the right door, trunk and rear seat locks (I only had a key for the drivers door and one for the ignition and console . . . the driver's door handle (maybe even the whole door) had been replaced at some time in the past.  I made a trip to pull-a-part and got a used window regulator for the driver's door and fixed the window.  I also got a replacement for the busted air filter housing.  I put brake pads on it not long after I got it too.
Then less than a month after we got it, the air quit working.  The next summer (after taking it to FL in June) Joy decided we needed to fix the air.  On this same trip, the cruise control starting crapping out.  Anyway, I had to replace the condensor and dryer and recharge it to get the air back online.  While I had the front clip off, I found the bumper was bent in the middle was what was causing the bumper cover to not fit quite right.  The next trip to pull-a-part, I picked up one.
Not long after that, the rear muffler busted open going to my brother's house and I stopped at Maxi-Muffler in Ft. O and got it replaced.
Then Carla ran in a ditch and busted the radiator.  Had to replace it.  While I had the front clip off (again) I replaced the bent bumper.  The new condensor was bent, but I got it straightened out and it didn't leak . . . but it's got a crease and I'm sure it's just a matter of time.
I decided to fix the oil leak at the valve cover.  While I had it off, I saw the timing belt was shot and the tensioner was locked down . . . and also found that it was leaking oil somewhere on timing belt side of the engine, so I ordered a bunch of parts - timing belt, tensioner and all the seals and gaskets for that end of the engine.  I should have replace the water pump while I was that far into it, but I didn't.  I'm sure that one will come back to bite me soon.  While I was working on it I replaced the used window regulator I put on earlier with a new one (the used one had already gone bad).  While I was at it, I replace the half broken driver's door handle and keyed it the same as the ignition key . . . now I've got two keys instead of three for it.  While I was working on it, I noticed the oil pan gasket seemed to be leaking, so I replaced it.  Heck, while I'm under it, I figured I might as well change the transmission filter.
Got all that done and figured out I still had a bad oil leak.  Either the flange gasket or O-ring or sending unit at the oil cooler/filter was leaking . . . I kind'a think all three, so I ordered those seals and gaskets.  Replaced them and stopped the leak, but now I've got oil pressure problems.
Somewhere in the middle of all that I snagged a headlight switch from Pull-a-part and fixed the lights.  Right after I bought it, the daytime running lights went out . . . and when you put on the bright lights, the tail lights and dash lights went out.  The new-to-me used switch fixed that.
Then came the door popping open . . . turns out to be related to the new door handle I had installed 6 months eariler.  Got all those problems straightened out yesterday.
I've got a wheel bearing roaring now, and it's starting to pull to the right.   ](*,)   . . . and in two years, I've never heard the radio.  Other than that, it's a good car.   8)
