Topic: split axle boots(swing axle) - make It easy  (Read 5865 times)
« on: June 02, 2004, 10:07:01 AM »
A lot of you clever folks may know this already. How many of you laid under your Bug cussing because the new boot will not stay on the side cover of the tranny long enough to get the clamp on?  Try this. If you have a " crows foot" with about 3/4 to 1 in. head on it, stick it between the spring plate and the spring plate stop.( you may have to have your S.O. stand on the door sill to make the Bug lay down on the that side) then when you jack the the car up the axle will more or less stay level with the side cover of the tranny. What!!! no crows foot? Grab that extra engine mounting bolt that you didn`t put back in ,install 2 17mm nuts with the flats together and used in place of the crows foot. I like to put the boot kit together out along axle and then push on the side cover flange with some kind of sealent.NO NO NO The split does not go up , but faces forward unless you really have a "jones" about changing boots all the time. Its also a good idea to have the clamps tighten at the split of the boot. When finished ,let the car down, roll it backwards ( with S.O. on door sill ) and remove crows foot or bolt. (DO NOT FORGET THIS) Now pour yourself a adult beverage,Kick back and tell yourselve you did a good job.
  Press On
  David
« Reply #1 on: June 03, 2004, 08:25:18 AM »
P S  If you have a pair of drive on ramps or a drive on lift(lucky you) in your back yard, You can disregard the B.S. in my last post.
    David
« Reply #2 on: June 03, 2004, 09:38:20 AM »
I'm not sure how the rest of ya'll feel, but we have received a supreme gift in David.
He has forgotten more about Volkswagens than most of us will ever know.
Thanks David!! :D
« Reply #3 on: June 03, 2004, 11:04:06 AM »
Thanks Herb, Yes I have forgotten a lot of " stuff" and after 40+ years I still don`t know everything about these "little critters" . They still defy all logic. They are living creatures you know. When Linda and I started "hanging" out with you guys at the few meetings we have been to , it started to re-kindle a interest in somthing I tried to forget about. Then it dawned on me that maybe I could help out the new owners of old VW`s .  I know there are young guys out there that have learned new tricks I haven`t heard of. Old f--ts like me can  still learn new tricks. I`m a good listener. All you have to do is ask and I will try to help. Dang It!!!! I guess I will have to get me a Bug or something so Linda and I can come out and play.
  David
« Reply #4 on: June 03, 2004, 11:12:16 AM »
PS, If I can`t find me a VW project I think I will get a VW emblem off of a van and put it on the front of my Volvo and call it a type 6. What do you think?
  Press On
  David
« Reply #5 on: June 04, 2004, 09:28:05 AM »
Nope David..........that won't work.............you've got to get another Volkswagen..........besides, Kyle has already done the VW emblem thing with a bus emblem on the front of his road tractor complete with a bug horn. :D
Edited By vwherb on 1086355779
« Reply #6 on: June 04, 2004, 09:47:55 AM »
WELL DANG !!!!   In that case, I think everybody should "chip" in and buy me a Kubelwagen. Works for me.
   By the way, how do you install the little smiley faces and little jems of wisdom at the bottom of your post ? like your "reckon so" . Remember, you are talking to someone who is computer challanged.(kan`t spale ethar)
  Press On !!
  David
« Reply #7 on: June 04, 2004, 07:49:49 PM »
The stuff that always shows up at the bottom of your post is your "signature."  You can type whatever you want and include "smilies" if you want to.  It's easy . . .
Once you've logged in to the message board, right under "Welcome Ret.Bugtech" you'll see some links.  Click on the one that says "Your Control Panel."  When that page comes up, click on the personal info tab and follow the directions.
If you post a picture on the web somewhere, you can use it for your "Avatar" . . . that's the picture that shows up under your name out beside each post (like my "superbus" emblem).
« Reply #8 on: June 04, 2004, 08:06:09 PM »
Thanks Zen. Are you still coming up to get your key stuff Sat.?  Call me at 1-423-802-7717 for some kind time thing
  David
« Reply #9 on: June 04, 2004, 10:04:15 PM »
Yep, I'm coming up for it tomorrow.  I was planning on calling you when I got through mowing the grass this evening, but I sat down and dosed off . . . and it's almost 10 now.  I'll call you early in the morning.
Edited By Zen on 1086401104
« Reply #10 on: July 06, 2004, 08:43:50 PM »
In the short time David has been posting on our forums I've learned a lot from him.  But after re-reading this post, I've got one comment to add.  This is for the benefit of you young males out there who haven't yet learned the tact necessary to deal with your "significant other" in these type matters . . .
. . . If you have a " crows foot" with about 3/4 to 1 in. head on it, stick it between the spring plate and the spring plate stop.( you may have to have your S.O. stand on the door sill to make the Bug lay down on the that side) then when you jack the the car up  . . .
NEVER, EVER, UNDER ANY CIRCUMSTANCE should you ask your S.O. to "sit here so the car will drop down and I can shove this crow's foot in here."   That crow's foot may get shoved somewhere else!  The proper way to do this is to ask them something like "Honey, can you help me out here?  Can you sit and tell me if you hear the *insert you're made-up part name here* behind the dash (that way, they will be sitting in the correct place, but looking away from you) clicking when I pry on the suspension with this crow's foot?  Shove it in where you need it and asked if they hear the clicking . . . when they say no (or yes, it really doesn't matter) tell them "Ok, honey, thanks for the help.  I've still got some work to do on it."  :;):
In other words guys, you are asking them to be a dead weight.  This is one of those cases where what they don't know won't hurt 'em.
PS.  If my S.O. gets wind of this post . . . well, it's been nice knowing y'all!   :p
 :cool:
Edited By Zen on 1089161112
« Reply #11 on: July 08, 2004, 12:23:19 AM »
Hey , Your are probley right. Maybe this what happen to my first S.O. who moved on. To many crowsfeet ?  Hmmm. Maybe its time for retraining (if you are that brave) or buy a S.O. who cares. I finally found one who knows or wants to know just about everything that I know. Before I know it, she will more than likely be installing the crowsfoot in the PROPER place.Yes, You young guys need to pay attention. After all,You are not going to buy that 911 Targa until you road test it are you ?? HA !!! :D   My S.O. approves of this message.(thank goodness)
