Topic: smutty plugs  (Read 2116 times)
Offline eakanator
  • Rome, Ga
smutty plugs
« on: October 05, 2006, 03:01:17 PM »
Even though the bug is running better, still getting a little backfire wither idling or if I start to slow down when I'm driving.
Went back and looked and the plugs on the drivers side 2&3 are still sooty, smutty, black powdery looking.  1 & 4 look great. I've looked for leaks and haven't seen any.
Any other tips as to why or what to look for as to why the only those two plugs look black (running rich ?, carb still may have crud? ) and could this be realted to why I still get a little backfire.
Ron
David O'
smutty plugs
« Reply #1 on: October 07, 2006, 10:01:59 PM »
Check the compression on the bad plugs and see if it is low, it could be that the valves are out of adjustment, and or the rings are broken or worn out!
