Topic: Shakey timing  (Read 4245 times)
Offline Kjmorton
Shakey timing
« on: September 05, 2014, 08:38:24 PM »
Hey all,
Timing question. I have a new svda dist w electronic module on a fresh rebuilt engine. My timing does not see as rock solid as I think it should be. I have a timing light from harbor freight with the adjustable scale.even when I have it on zero, the mark seems to flicker in and out of time. Possible related, when I use the optical tach, the rpm can have as much as a 50 rpm difference. I suspect the coil.
checked the spark and it seemed to look bluish yellow. When I used a ohm meter, it looked like my resistance was 6. Of course, I'm not an sure I was using it correctly. I do not want to drop the money on a coil if it isn't the culprit. Ideas?
Re: Shakey timing
« Reply #1 on: September 06, 2014, 05:42:23 AM »
The variation in the timing could be causing the variation in the RPM . . . or the variation in the RPM could be causing the variation in the timing.  I wouldn't think the coil is the culprit.  My first suspect would be the distributor bushings worn, but if you have a new distributor, that "shouldn't" be the problem . . . but quality control in the automotive parts industry isn't what it once was.  I have gotten my fair share of "good, name brand" parts that were bad right of the box.
When you check the timing, are you checking it at idle or at full advance?  At anything less than full advance, the centrifical and vacuum advances can move around some and cause the mark to dance around several degrees, but once you hit the full advance, with a new electronic ignition distributor, it shouldn't dance around any.  Under full advance, it should be set to fire at 32 degrees before top dead center.
Offline Kjmorton
Re: Shakey timing
« Reply #2 on: September 09, 2014, 07:26:36 PM »
Could the erratic rpm be caused by the carb. I've been dying at intermitantly at red lights lately. I've adjusted bye book. Dies if I blip the throttle a few times in a row. I'd is This a different problem?
Re: Shakey timing
« Reply #3 on: September 09, 2014, 09:15:40 PM »
YES!  A lot of "ignition problems" turn out to be carburator problems, and visa-versa.
