Topic: Relay configuration for my 78 bus?  (Read 2454 times)
78HippyBus
« on: April 05, 2007, 02:33:11 PM »
Hi guys, just bought a 78 bus and it has 4 relays beneath the 12 fuses. Can anyone tell me the purpose of each of the 4 relays left to right?
    I found that the hazard switch is damaged and have ordered another one. Right now only my hazard lights, blinkers, and reverse lights are not working...and the headlights, bright and dims, parking lights, and brake lights do work. Thanks for any info!
« Reply #1 on: April 05, 2007, 06:23:59 PM »
From left to right:
1.  Turn signal/emergency flasher relay (the biggest relay).
2.  Headlight dimmer relay.
3.  ?.
4.  Ignition key warning buzzer.
My '78  and '79 only had 3 relays under there.  The ignition key warning buzzer is usually taken out because it is so annoying...mine is in the glove box.  I don't know what the 3rd one would be.  Maybe someone else knows?
