Topic: rebuilt vs new engine / talk to me, please  (Read 1991 times)
Offline gpeck
« on: March 04, 2010, 07:11:07 PM »
Good evening,
my 1973 westfalia camper has major engine problems. Cylinder 3 has 0% compression and 4 has 10%. in the past i had little problems, but had to replace the left cylinder heat 2 since the bushings came loose.
I will get the detailed damage report tomorrow and can fill in some more specific lingo.
Looks like i would have to
option 1:
 find somebody, who could rebuilt the 18oo cc engine and get a couple of new cylinders.
option 2: get a used or new engine and have it put in.
Would option 1 really be cheaper in the long run and where can i get a professional "engine rebuilder" or a new engine?
any help, suggestions, websides etc. greatly appreciated.
gp
Offline bubbz
  • Life is good!!
Re: rebuilt vs new engine / talk to me, please
« Reply #1 on: March 04, 2010, 10:21:20 PM »
Welcome  I dont know much bout the 73 campers and what motor parts are like, but you have came to the place for great info. some of these guys wrench vw for a living.
« Reply #2 on: March 05, 2010, 01:06:01 PM »
Hey, You can rebuild if you can find parts. They are getting harder and harder to find parts for and you just about need a Federal Grant if you do find them. I don't believe there is such a thing as a re-build "Kit".
    As far as getting anybody around here to do the job is next to impossible. Most of the old time VW savy Mech. around here will run and hide when you mention Type-4 engines.
     Used engine verse New engine ??  If you go with a used engine you had better get some accurate history and maybe some kind of warranty .  New engine ? Good luck . There are some people out there selling "so called" rebuilt engine mostly out west. They are expensive and you pay the shipping. Some of these company's have a warranty but you have to ship it back to them at your expense if something goes wrong. They then determine if the problem was their fault or yours. I think you know where I'm headed with that one.
     I know you didn't want to hear all of this but after 45+ years in the trenches with VW's I did learn a thing or two.   Where you located ?
« Reply #3 on: March 05, 2010, 05:12:01 PM »
If you want to stay with the type 4, it would probably be best to rebuild yours . . . but like RetBugtech said, get ready for some sticker shock when you start shopping for the parts.  With a type 1 engine, I'm not afraid to throw a bunch of used junk parts together and see what happens.  That's not a good idea with a type 4. Either do it right or don't bother.
Jake Raby over it Cleveland, GA can probably supply you with any of the parts or machine work you need to build a near bulletproof type 4 that will run over 100,000 miles, make way too much HP for a bus and run cool and get great gas mileage at the same time.  But, it'll cost you.
Or, you can convert it over to a type 1 engine.  A stock 1600 will push a Westy down the road at a reasonable speed . . . as long as you don't hit a strong headwind or a steep hill.  ;)  I've been running a type 1 in my 73 bus for almost years now . . . I think I'm on my 5th engine, but I'm probably still better off dollar-wise than if I'd fixed the blown type 4 that was in it originally.
Offline 74loaf
  • Hixson, TN
« Reply #4 on: March 06, 2010, 06:24:26 PM »
Or you can always do like what I did for my 74 bus.
I bought a rebuilt engine from GEX.... some people don't like them, but I've put about 3000 miles on mine and had no problems so far. Total cost was 2400 shipped, and you get some back if you send back your old block. Since the price was the same, I upgraded to a 2.0 instead of a 1.8, and they even switched over the drive plate for me instead of a flywheel since mines an automatic. Only thing I had to do was use an electric fuel pump since the 2.0 block doesn't have a place for a manual fuel pump..... just my 2 cents....
