Topic: push rod tubes  (Read 4556 times)
Offline 73boobjob
  • hixson
push rod tubes
« on: May 05, 2011, 02:16:58 PM »
how to the tubes fit in the head ,do they screw in or just push in
Re: push rod tubes
« Reply #1 on: May 05, 2011, 03:39:56 PM »
The regular stock push rod tubes get sandwiched between the head and the block with white rubber-like grommets on each end (the seams in them face up). If you are talking about aftermarket ones, there are some that screw out like a shower curtain rod and then some are just spring loaded. Which ones are you talking about?
Offline 73boobjob
  • hixson
Re: push rod tubes
« Reply #2 on: May 05, 2011, 03:50:08 PM »
I blew a head gasket was going to fix it my self but after looking at it ill pay someone
Re: push rod tubes
« Reply #3 on: May 05, 2011, 04:04:25 PM »
If it's a type 1 engine it doesn't have a head gasket.  If you are leaking compression between the head and cylinder, you may have a broken head stud, a stud pulling out of the block, or the head may just need to be retorqued.  What is it doing (or did it do)?
Offline 73boobjob
  • hixson
Re: push rod tubes
« Reply #4 on: May 05, 2011, 04:06:01 PM »
Its blowing out between head and jug
Offline 73boobjob
  • hixson
Re: push rod tubes
« Reply #5 on: May 05, 2011, 04:07:52 PM »
Its on no. 1 when i took off head bolts the one on the end was kinda loose
Re: push rod tubes
« Reply #6 on: May 05, 2011, 04:47:23 PM »
Why did you take the head nuts off for ? This a bug ?  Engine still in the car?  How did you get all the head nuts (8 of them) off without removing the sheet metal(jug covers) fan housing.
   I think you may be in trouble now. You need to tell us what you are driving before you start tearing stuff off . May save you a lot of time and money.
Offline 73boobjob
  • hixson
Re: push rod tubes
« Reply #7 on: May 05, 2011, 04:56:17 PM »
Its a bug with a 1600 in it I think i will put it back together before i do get in deep shi=
Offline 73boobjob
  • hixson
Re: push rod tubes
« Reply #8 on: May 05, 2011, 04:58:16 PM »
motor is in car took off 4 head nuts
Re: push rod tubes
« Reply #9 on: May 06, 2011, 12:12:40 AM »
Put them back on. Torque to 18 ft pd if you have 8mm stud, 25 ft pd if you have 10 mm head studs . You need to know which stud you have. Very important. You will have to re-adjust the valves on both sides of the engine. 006.
Offline 73boobjob
  • hixson
Re: push rod tubes
« Reply #10 on: May 06, 2011, 09:24:33 AM »
Thanks for the info
Re: push rod tubes
« Reply #11 on: May 06, 2011, 09:42:57 AM »
Thanks for the info
Lets hope that this will seal the head somewhat and doesn't have a head stud stripping out.  Most of the time its the 10mm stud that will give you some problems. You will find out when you torque the head because you can't torque to 25 lb without stripping. Torque the center nuts first. Keep your fingers crossed.
Offline 73boobjob
  • hixson
Re: push rod tubes
« Reply #12 on: May 06, 2011, 01:41:32 PM »
i tightend the head nuts put it back together and it dont leak anymore.Still need to do the valves
Re: push rod tubes
« Reply #13 on: May 06, 2011, 04:09:08 PM »
Thats good to hear. Don't run it long without adjusting the valves. That thing has to breath!
