Topic: old skewl motor build  (Read 2249 times)
« on: July 09, 2008, 11:59:31 PM »
Started gettin together parts for a 1904 motor.
74mm cb crank
90.5 mahle forged pistons
041 big valve heads
duel Zeniths yeah duels again :lol:
Cb deep sump
Berg full flow
berg equalizer pulley
saving up for the Berg linkage. The idea is an old school tribute to an 1800 stroker from back in the day, Some crazy ole fella gave me the idea. 8)
The guys at CB are sayin with the 74mm crank I can use A(non stroker pistons) Does that sound right? They said B pistons (stroker)are for 78mm and up cranks???
« Reply #1 on: July 10, 2008, 08:12:34 AM »
When I built my 1850 years ago using C.B. stuff, I had to use the 88mm stroker piston on a 76mm shaft. I don't know about the 74mm crank.
     Your 74mm will have a 5mm gain over the 69mm stock crank and I suppose they will want you to do some serious cyl. decking do to the stock wrist pin location on your 90.5 cyl.  You better have the stuff to do this and get it right and I mean right.
      You better rethink about using duel Zeniths DINX , if this was your plan.  Porche tried this on some of the 356's and found that they blew more gas out of the top of the carbs than was going in much less being a hassel to keep adjusted.  Porche " Normal"  ran the Zenith as a single and did pretty good with it.  They finaly went Solox.
       Are you going for a new case ? It just money.
       Good Luck :roll:  :roll:  :roll:
« Reply #2 on: July 10, 2008, 08:56:14 AM »
I'll bet he's gonna put it in a hack-job trike....... :razz:
« Reply #3 on: July 10, 2008, 09:38:21 AM »
------- Just when I thought there was hope.  Oh well !!! :roll:  :roll:
« Reply #4 on: July 10, 2008, 11:32:45 AM »
Probably a new case as well. Just thought I'd start a thread on it and get everyones imput. Plus I knew it would be a great opertunity to mess with the Godfather. :lol:
This thing is like all other projects,I'll finish it.................someday?
« Reply #5 on: July 11, 2008, 08:15:43 AM »
Its always better to be messed with than messed on and just remember you will never be able to out-mess me. I just love reformed "whipper- snappers"   Do-Dar, Do-Dar !! :lol:  :lol:
« Reply #6 on: July 11, 2008, 09:41:16 AM »
Unable to out mess you...are you tryin to say your the cheif mess maker? Im sure your wife would agree.
Well I wouldnt dare try to compete for that title you can have it. :lol:
Any clue on that a versus b piston thing on a 74mm crank?
« Reply #7 on: July 11, 2008, 10:05:21 AM »
The words  Mess or Messing is a generic term for the benefit of those who seem to have freaky things that manifest themselves without having a clue to know what happened or why.   Example: I don't what happened ,but this oil pump is "Messing" with me.
      The A versus B Piston ?   I don't have a clue , I haven't "Messed" with anything like that :lol:  :lol:
« Reply #8 on: July 11, 2008, 10:54:29 AM »
