Topic: Oil Question  (Read 17744 times)
Oil Question
« Reply #15 on: December 07, 2007, 07:56:15 PM »
Bugtech,  You are being silly, dog poop  only lasts  12.3  minutes as a lubricant  before it loses viscosity  and turns flammable. Not to mention the smell.   You should have learned that at VW school .  geeez.   sc
Oil Question
« Reply #16 on: December 08, 2007, 11:00:39 AM »
I wouldn't think that would be a problem. Stupey only runs 10.46 mins. at a time doesn't he ?   Plenty of time to re-load.  Flamable ?  Does Frank know about this ?   Poop 101 wasn't discussed at VW school until they came out with the Type-4.  This was after my time thank goodness :roll:
Offline Bigdummy
  • Ft Worth , Texas
Oil Question
« Reply #17 on: December 08, 2007, 05:19:53 PM »
actually my question really was should I use detergent or non?....Thanks agian....Fred
Oil Question
« Reply #18 on: December 08, 2007, 11:38:16 PM »
Detergent.
Offline Bigdummy
  • Ft Worth , Texas
Oil Question
« Reply #19 on: December 09, 2007, 09:43:25 PM »
Thanks!
Oil Question
« Reply #20 on: December 10, 2007, 01:16:59 PM »
Hey Fred,  I should have stated    20w50 High Detergent.  VW aircools seem to like to cruise with Castrol.
Oil Question
« Reply #21 on: December 10, 2007, 03:41:42 PM »
Not to sound like a big dummy, but...what's the difference between detergent and non-detergent? (And don't just tell me one has detergent and one doesn't.) How can I tell by looking at the bottle? I just use Castrol GTX 20w50.
Oil Question
« Reply #22 on: December 10, 2007, 05:21:18 PM »
Well its sort of like this.+ " What's the difference between Kinky sex and normal sex ?"  The anwser is ----  About $15.00 :lol:  At one time long ago " Kinky Sex cost a little more.
     Some folks say the "HD " on the can means Heavy Duty ,  some think it means High Detergent. I have seen more cans marked Non-Deregent than marked High Detergent.  Most all the major brand muti-viscosity oils are High Detergent. I don't even think there is a 10w30, 20w50 etc. Non-detergent oil .  I might be wrong.   GTX is High detergent though.
     All this info is for normal people . Smelly Cat makes his own oil thanks to his buddy Frank and his Hound Dog. :lol:
Oil Question
« Reply #23 on: December 12, 2007, 08:33:39 PM »
Thanks Bugtech.   expensive oil  = expensive drips in the driveway.  Tts like vitamins.  You buy, eat,  and excrete..  just like a VWmotor treats oil.  SC
Oil Question
« Reply #24 on: December 13, 2007, 08:06:40 AM »
What !!   Your Stupey leaks oil ?   I can't imagine !! :roll:
Oil Question
« Reply #25 on: December 14, 2007, 08:26:22 PM »
Ya poor Stupie....  leaks oil  like a stuck pig.  Make that a stuck oil Drum.  Maybe 50w leaks out slower?  I was gonna drive it today but the oil light was flickerin last time I drove and decided  against  adding a quart of Smelly Special Oil in the dark.  Is there any good products like "BugTech in a Can"that will fix my main seal ?  sc
Oil Question
« Reply #26 on: December 15, 2007, 10:17:43 AM »
That "Bug Tech" in a can stuff doesn't work  well at temps below 35 degrees but it is available.  BugTech Stuff , the heated garage version, works really well. :lol:  :lol:
     Driving with a blinking oil light is going to jump up and bite you one day.  It doesn't take to many times .  :(
Gehackt
Oil Question
« Reply #27 on: December 19, 2007, 12:12:03 AM »
Sooo.......What would you reccommend for the -10 to 30 desgree weather???
Joe
Offline Kyle
Oil Question
« Reply #28 on: December 19, 2007, 01:01:59 AM »
Not going outside!!! #-o
SC-  I say if it don't leak, it must out of oil1 :badgrin:
Oil Question
« Reply #29 on: December 19, 2007, 12:16:19 PM »
What weight oil in -10 to 30 degrees weather ?   Other than what Kile stated ( which sounds good to me) that is a good question for your part of the woods.    10 w30  maybe ?   For the type of weather around here 20 w 50 works for us.   Its pretty rare to get low temps like you guys get.
     You could move down below the Kudzu Belt then it would't be a issue :lol:  :reindeer:
