Topic: oil pump  (Read 2883 times)
oil pump
« on: July 09, 2008, 09:24:47 AM »
oil pump is bad so no oil pumping.Gotta go through it all to make sure theres no hidden blockage. Fun fun.
oil pump
« Reply #1 on: July 09, 2008, 01:08:42 PM »
Do you have the right pump for the camshaft ?    flat or dish cam.
oil pump
« Reply #2 on: July 09, 2008, 04:35:19 PM »
Yep,couldnt get oil pressure,took it apart blew out the passages and checked the relief valve.. The pump just decided it was time to die. :lol:
This is why I absolutley hate reusing parts!
oil pump
« Reply #3 on: July 09, 2008, 05:15:04 PM »
Yikes!
oil pump
« Reply #4 on: July 09, 2008, 11:46:02 PM »
Wouldnt it be nice to assemble 1, just 1 with all new parts?Thats what make stroker motors sound so good. Sure it's a pain setting rocker arm geometry and deck heighl but nobodies even gunna think of reusing a 30 year old oil pump on it. :lol: I did manage to crank  out an 1835 this week.Not a stroker but still fun.
Didnt have any used parts there. Fella picked it up today and drove off to Hotlanta in his baha.Thats good cant have a baha sittin around the house,gives the wrong impression. It is the 1st raised beam I've ever adjusted....weird aluminum beam???? :oops:
Oh and on the post subject,I'll probably come out for a bit I need the break from the stuffy garage.
oil pump
« Reply #5 on: July 09, 2008, 11:54:13 PM »
Well !!  Pretty weird that it would not pump something. I never have had a pump that wouldn't pump some kind of pressure. Hmmmm
oil pump
« Reply #6 on: July 10, 2008, 12:02:00 AM »
It pumped just enough to turn the oil light off. Then at about a minute into it it squeeled and the light came on.
oil pump
« Reply #7 on: July 10, 2008, 08:15:52 AM »
Fess up when you find the problem :lol:  :lol:
oil pump
« Reply #8 on: July 10, 2008, 09:14:03 AM »
Did you lock up the engine ?    I think I know happened but I'm keeping my mouth shut until the truth is known.  Squeal ??
oil pump
« Reply #9 on: July 10, 2008, 11:43:39 AM »
Please enlighten me cause I cant seem to find what would make a good oil pump go south in less time than it takes to type this. :lol:
oil pump
« Reply #10 on: July 11, 2008, 08:00:00 AM »
Well you need to enlighten me. I'm not looking at the pump.  What did you find ?  Gear spinning on the shaft ?    locked up ?   broke the drive gear?   mis-match gears,  wrong pump for the wrong cam ?  Gears ate the cover or housing up ?    Have you even pulled the pump off yet ?
     Why don't you bring the pump to the cruise-in tonight and we will look it over.
oil pump
« Reply #11 on: July 11, 2008, 08:57:40 AM »
Sorry,  Just read your P.M.   Strange that it locked # 1 main. I have a case on the floor that had the oil galley plugged from the rear (fly wheel end) cam brg. up to the main brg with Dirt-Dauber mud. Never could get it out.
      I wonder if anybody has ever found something that would eat that stuff. Its like concrete.  I even tried muratic acid. No cigar.
      I want to see that pump anyway. :roll:  :roll:
oil pump
« Reply #12 on: July 11, 2008, 09:38:34 AM »
I'll try and find where it landed,it seemed to fly outta my hand during an onslaught of damnits. :lol:  If I get caught up,I'll be there tonight.
