Topic: Oil leak behind crankshaft pulley - can it be fixed w/o taking engine apart?  (Read 8158 times)
This is on the Vee's 1200.  As I look at the books, it looks like all you've got is a front bearing and the oil slinger, and no donut-type seal.  Is the bearing giving out if it starts to sling a lot of oil from here?  Can anything be done without splitting the case?
There is no seal there.  The stock pulley has some spiral grooves cut in it (looks kind'a like it's threaded).  I understand that these are to not only sling oil back into the engine, but to draw air in as well.  The air flow helps pull the oil back into the engine also.  I know I've looked at it before, but I can't remember . . . does it have a stock pulley or an aftermarket?  Lots of the aftermarket ones don't have the grooves.
If you have a stock pulley my guess would be that you are either too full of oil, or the crankcase breather isn't doing it's job.  We plugged off the crankcase breather on Justin's 74 Super when it had a 1600 dual port in it, and the first time we crossed Monteagle it blew over a quart of oil out around the pulley.  We hooked the breather back up and it never leaked there again.
Also, I remember you showing me that there were extra marks on the dipstick . . . I've thought about those and maybe there is a full mark for when you first turn the engine off . . . then after it sits overnight the oil drains back down out of the oil cooler and you have to use the top full mark.  I'm just guessing there, but that's all I can think of.
If the rear bearing is bad enough to cause an oil leak around the pulley, I would think that everything else in the engine would be in very poor shape.  In the engines I've torn down, that bearing is usually in the best condition of all the main bearings.
Makes sense to me.  I'll have to check the SCCA rulebook to see if there's a reason it doesn't have some sort of PCV system.  For those who haven't seen it, what it does have is a tube to catch blow-by out of the filler neck and send it to a catch-cup behind the motor.
Thanks!  I've still got a lot to learn about these Vees!
