Topic: oil in my head  (Read 5357 times)
Offline swagginjello
  • cleveland, tn
    • facebook...
oil in my head
« on: July 23, 2008, 07:22:15 PM »
went to check my valves today, and pulled off the cover to find almost half a cup of oil in my  cyl 1,2 head, the other head only had a bit, like normal. i do park on a bit on an incline but that seems really high.  all the valves check out to be close, anywhere from .005-.007.  also there was some metallic shimmer to the oil...  any thoughts before i start pulling it apart... can i drive it five miles to where i would like to pull it apart.
oil in my head
« Reply #1 on: July 23, 2008, 09:40:33 PM »
The incline might explain the excessive oil behind the cover, what makes me a bit more concerned is this "metallic shimmer".  Have you been hearing any of those nasty noises lately?  Been using oil?  (more than normal, if that be the case?)  double check the tightness of the rocker arm shafts, I've seen several of those in the last year where the nuts have backed off allowing the shaft assembly to move around.  Common sense should apply to all of this.  Safe to drive????  dunno.  An engine can go from nuthin to holy crap in under 5 seconds, but again, you should usually see some sort of sign first.   One last thing, check the metallic shimmer with a magnet, no attraction, aluminum, clumps up on the magnet, it's steel.
  • cleveland, tn
    • facebook...
oil in my head
« Reply #2 on: July 23, 2008, 11:11:32 PM »
heard a little noise yesterday after i adjusted my timeing down a bit yesterday, so i decided that id check my valves to day, but it didnt sound like that side of the engine, not that i can hear to well. the other head really didnt look to have and shimmer to it, but it only had a few drips of oil to tell by. the intake valve on cyl 2 is adjusted out farter than the rest, but its been that way for a while. as for the magnet test... i used a wand magnet... all i had around, but it did pick up a few bits here and there. i think alot of the shimmer stayed on the head cover when i pored it into a jar....
oil in my head
« Reply #3 on: July 23, 2008, 11:24:21 PM »
Also if you are close to a oil change you can take a close look at the oil strainer plate . You are bound to see some "stuff" on the surface. If you see some copper or brassy looking stuff you might be headed toward some problems.
  • cleveland, tn
    • facebook...
oil in my head
« Reply #4 on: July 23, 2008, 11:27:00 PM »
less than 1000 miles since last oil change, and dosnt seem to be lossing excesive amounts of oil, but it did sit for about 2 week on the incline...
oil in my head
« Reply #5 on: July 24, 2008, 01:14:39 AM »
David's comment about the strainer plate reminds me.  Is this an upright or later (type 4) engine that we're talking about?
oil in my head
« Reply #6 on: July 24, 2008, 08:47:50 AM »
Rick, I belive its a convert to a Type-1.
  • cleveland, tn
    • facebook...
oil in my head
« Reply #7 on: July 24, 2008, 01:58:30 PM »
correct it is a type1 convert.
oil in my head
« Reply #8 on: July 24, 2008, 04:11:35 PM »
GLAD to hear it!.....like David said, I'd be looking at the sratiner plate for the mushy metal lump.
  • cleveland, tn
    • facebook...
oil in my head
« Reply #9 on: July 24, 2008, 05:52:00 PM »
i supose i can pull it open, but being on the hill might throw it off a bit... id be nice to have some level ground, but im scared to drive it at the moment
  • cleveland, tn
    • facebook...
oil in my head
« Reply #10 on: July 27, 2008, 08:23:51 PM »
here are some pictures and info.
pulled off the head to see if more oil had pooled there, and it seemed that it had. pured most of the oil out and heres a picture of some metal flakes in the cover.
Decided to drain the oil, and check inside a bit.
pulled the drain cover to find crap in it. looks like fine metal, and peices of something. maybe a shim...
dosnt look good, but i didnt see anything brassy.
oil in my head
« Reply #11 on: July 27, 2008, 10:32:30 PM »
Is that stuff aluminum ?    Stick a magnet on it.  It might be from a piston skirt. Has this engine ever dropped a valve or burned up a piston and was" patched" up without spliting the case ?  Just a guess. :-k  :-k
oil in my head
« Reply #12 on: July 28, 2008, 08:00:25 AM »
I must agree, looks kinda like a chunk o' ring and the fine suff looks like aluminum.  Magnet time.
oil in my head
« Reply #13 on: July 28, 2008, 08:19:03 AM »
I think I would be finding out whats going on in there very,very soon, I mean like now !! :(
  • cleveland, tn
    • facebook...
oil in my head
« Reply #14 on: July 28, 2008, 08:45:22 AM »
burnt a piston march of last year... so sounds about right. as for the metal  seems to be magnetic, but may be a mix.
