Topic: Not leaking oil and finaly not dead.  (Read 17533 times)
65dunebuggy
« Reply #30 on: April 04, 2006, 02:31:52 PM »
That's going to be a bugtech question.Do you live near him?Too far away?But question wise call for him.Think he left his telephone number on here bugnut. And he his retired.Give him a call. 8)
« Reply #31 on: April 04, 2006, 03:02:20 PM »
Are you talking about the fuel pump push rod in the case or you just can not move the fuel pump lever in the pump. Some of the pumps can be a "bear" to move. Does it pump when the engine is running ? Is this the same pump you have been running ?
     I might go $350 if you get a little madder :lol:  :lol:  :lol:
« Reply #32 on: April 04, 2006, 03:55:01 PM »
Sorry price just went up! Had to do a little reading in the manual.It's working fine. Now it just needs a tune up.Any tips for setting the valves?
Weird thing the car spit water at me! Must have got some in the exhaust when it was off the car.
« Reply #33 on: April 04, 2006, 03:57:38 PM »
Books is good 4 readin. I learnt sumthin. U got a dixtionary? :lol:
« Reply #34 on: April 04, 2006, 05:44:08 PM »
Yea I du.  Du u pose u could fine # 1  Zinledar ?  Cal me and I wil tell ye how. :lol:  :lol:
« Reply #35 on: April 04, 2006, 11:32:03 PM »
yep I'm getting good at finding TDC.Found that funny sound it's an exhaust leak. Ive got a stipped stud bolt or rather the casing is stripped. I gotta figure a way to fix that, then I'll get with you about the valves.
I'm readin the book it seems pretty straight forward forchecking the clearance on the valves. To bad I didn't do it when it was on a table. :tard:
« Reply #36 on: April 04, 2006, 11:36:03 PM »
Hey 65 Dune,Trust me we all know where David lives. :lol: It's one of the first things I found when I got on here. mater of fact He was the first to look it over for me.And I'm lucky cause it's real close for me.  :D
65dunebuggy
« Reply #37 on: April 05, 2006, 02:00:28 AM »
Then you are very lucky Bugnut. 8)
« Reply #38 on: April 05, 2006, 08:24:50 AM »
Stud bolt ?  Casing ?   Are you saying exhaust port stud in the cly. head ?   To bad you didn't find that before you installed the engine. Don't let your valve adj. slip by . If you have had the rocker arms off you can bet the valve adjustment is off. You don't want to burn those puppys up in case a few of them are tight. :(
« Reply #39 on: April 05, 2006, 08:48:22 AM »
Scott, Do you still need the D.S. tube? I have one out for you.
65dunebuggy
« Reply #40 on: April 05, 2006, 11:19:20 AM »
Did ya'll ever figure out what size the came out factory?Did you say inch and a half?
« Reply #41 on: April 05, 2006, 11:39:13 AM »
I checked five different cases and the tubes were  sticking out of the case about  1 1/2 inch give or take a  1/16.
65dunebuggy
« Reply #42 on: April 05, 2006, 11:47:35 AM »
Ok.I wanted to check mine since we were on the subject.Thanks Bugtech.
« Reply #43 on: April 05, 2006, 02:52:58 PM »
Yep a stud bolt in the casing was stripped,I gotta do a better job going over it all next time. I retapped it and it seems fine for now. I do still need the D.S. tube,I'll give you a call tommorrow if thats ok? I adjusted the valves but the seem to rattle a little not sure if they did before couldn't hear them over my ratty exhaust. i still have to recheck my timing and adjust the carb. Then I have to get a tin for the bottom end and it will be on the road.
Thanks.
65dunebuggy
« Reply #44 on: April 05, 2006, 03:09:23 PM »
"On the road again.Just can't wait to get on the road again" lol. :lol: Go for it bugnut!!!!!!!!!!!!!!!!!!!!!!!!!!
