Topic: Not leaking oil and finaly not dead.  (Read 17535 times)
65dunebuggy
« Reply #15 on: April 01, 2006, 10:20:06 AM »
Well I didn't know any better back then lol.Live and learn.
« Reply #16 on: April 01, 2006, 07:05:20 PM »
Well I guess I've about got it fixed. Turns out I had a clogged up oil galley in there and the oil pressure relief was stuck. Maybe that would explain it. Turns out also that engine was missing alot of gaskets and alot of the bolts were mismatched and so forth. Gotta gasket kit and a bolt set and reassebled it all. Repainted everything as well,it's pretty .Hell it might even run right! :o
I'm missing an oil dipstick tube and a engine mounting bolt that I can't seem to get.I'll give a few days and see if one turns up.
Meanwhile  I'm cleaning up the undercarrage and such. Dang thing is nasty under there. I think I'll do some work on my fuel lines as well ,they look a bit shady.
Well back to the garage.
« Reply #17 on: April 02, 2006, 12:36:38 PM »
Scott, I checked a couple of dip stick tubes in some cases I have. They all seem to stick out the case about 1 1/2 inches. A trick I use to do is use a drill bit that just barely would fit into the tube so you wouldn't collapes it and then use a good pair of vice-grips to clamp around the tube. Take a #1 tool(hammer) and peck on the vice-grips to move the tube out. The tube is snug in the case ,but will move. You may not have to replace the tube . The tube is about 4 or 5 inches long and you may just have to move it out far enough to get your 1 1/2 inches. The way it was you were running the engine low on oil. maybe 1/2 qt or more.
     I bet you are missing the upper engine mounting bolt on the driver side .Correct ?
      Let me know how you made out on the tube
« Reply #18 on: April 02, 2006, 04:12:21 PM »
I got it out and I found a piece of brass pipe that seems to work,I was just about to ask about that measurment. :lol:  And yep I am missing that mount,How did you know that?Do I need to check my garage for video cameras?
Is it ok to fabricate that oil tube?Anything that I need to be aware of? The motors about ready to put back in,I just have a little more cleanup on the chasis before I do it. I'm also gonna have to set the gap for my valves and such any advise? Thanks for the help.
65dunebuggy
« Reply #19 on: April 02, 2006, 04:50:09 PM »
I really don't think his got a camera but has been around to see this or have done this before. Maybe several times. 8)
« Reply #20 on: April 02, 2006, 10:44:56 PM »
I'm sure theres some nutty reason it happens.why would someone do that? I don't get it.
65dunebuggy
« Reply #21 on: April 03, 2006, 12:31:19 AM »
Bug Tech has been around for a while.He knows alot of things.My hat is off to him.Listen to him for his wiseness has alot to do with it.But of course I would like to slapp him myself.Because he knows too much.But I will say this.Herb knows how to put on a show!He really does.He makes it something else.The eat's are great!I thing his wife does alot too.Thank you Dee! May have spelled it wrong.And then the club pres.old Z.He has a great attitude!I wish I had enough money to help him finish his bus.Maybe one day I will.Old Homer could use a little help.But ya'll are great guy's.Thanks for being that way! I hope I make it there because ya'll are good people!Made it in BP 6 I hope to be there in BP 8.Yall get rid of Alan with his dunebuggy(black and brown)so I can pull off a better trophy.Lol just kidding.Nice looking Buggy.Tell him to win it with something else lol.
« Reply #22 on: April 03, 2006, 01:09:54 AM »
I have a old case that I can get the tube out of. Brass might be a bit to soft to drive in.
« Reply #23 on: April 03, 2006, 01:35:22 AM »
good point as always.Thanks Again.
65dunebuggy
« Reply #24 on: April 03, 2006, 05:13:19 AM »
Just call me a young fool back then.Now call me an old fool :lol:
« Reply #25 on: April 03, 2006, 11:15:54 AM »
Old Fool at 51? Just wait until you are my age and about half of everything in your shopping cart says " For Fast Relief " :?
65dunebuggy
« Reply #26 on: April 03, 2006, 03:38:13 PM »
Lol.You are not old.Because you are only as old as you feel.And I feel pretty old.Bugtech,what made me feel old was when Cathy (my wife)and I were sitting in front of the tv and a aarp insurance commercial came on.They were saying if you are 46-75 we need this insurance.It use to be alot older than that.My mouth was hanging open.They have changed their age requirement's now.lol :lol:
65dunebuggy
« Reply #27 on: April 03, 2006, 03:39:55 PM »
Now you can get certain senior citizens discount's at 55! What up with that? :lol:
65dunebuggy
« Reply #28 on: April 03, 2006, 03:41:22 PM »
Oh yea bugtech.It's ok it say's for fast relief.Who want's slow relief anyhow? :lol:
« Reply #29 on: April 04, 2006, 01:50:08 PM »
I'm about to murder this car! Alright the engine is in when I start it up it's running a little rough no big deal I knew I'd have to set the timing a little. There was a pinging sound so I shut it off,I think it was the fuel pump.Anyways I took it off and was checking it out and the push rod won't go up and down. What now? This thing has me madder than a hornet! I'm gonna kill it!
