Topic: next question  (Read 2818 times)
Offline Bigdummy
  • Ft Worth , Texas
next question
« on: December 21, 2012, 07:14:09 PM »
ok gurus how do i determine which fuse for what circuit   like what fuse 10 , 15 30 for ignition lights etc. thanks agian ???
Re: next question
« Reply #1 on: December 22, 2012, 10:49:40 AM »
The idea behind a fuse is to allow the circut to operate normally, but if it starts drawing too much power, shut it off.  If the fuse is too small, it will blow when nothing is wrong.  I it's too big, it doesn't protect the circuit like it should and you could fry componets or wires.
If there are no problems and everything is working correctly, you could do it by trial and error . . . start with small fuses and keep replacing them with bigger ones a step at a time until they quit blowing . . . but if you have a short, you'll eventually get to a fuse that is no longer the weak link . . . then stuff fries!
I would get a wiring diagram for a late 60's/early 70's bug and look at the size fuses they use for each circuit.  This should get yoiu in the ball park.
Re: next question
« Reply #2 on: December 22, 2012, 12:17:23 PM »
Everything uses a blue one. Except for the headlights, they are the yellow ones I think.
Maybe that's something else  ;D
Re: next question
« Reply #3 on: December 22, 2012, 02:40:14 PM »
Do you know about the red and white fuses ? They all have different values. Sure you can use all heavy amp fuses until a little gremlin pops up on a  component  that draws only 8 amps. be fore it "blows".  Its the glowing part followed by smoke then fire that sort of gets  my attention every time. :o :o
Offline Bigdummy
  • Ft Worth , Texas
Re: next question
« Reply #4 on: December 31, 2012, 12:06:22 PM »
I am using spade fuses and a 6 spot box, so oooooooo what ya think, just one headlight and tailights a radio turn signals brake lights. ???
Re: next question
« Reply #5 on: December 31, 2012, 12:49:18 PM »
I think if you find out the wattage of the headlight, you can calculate the amperage draw, which will let you size the wire and the fuse for that circuit. As for the other items, I'd look at comparable setups and review thinks like what fuse is used for a horn and take into account what else is on the circuit. Then you put in a fuse and if it blows, step up. But remember, the fuse is meant to blow before a wire carries more than it's maximum allowed amperage, so don't overload a wire!
