Topic: New Beetle CVs and Wheel Bearings - What's involved in changing them?  (Read 3883 times)
I need some advice about a problem with Justin's '98 New Beetle.
What is the best approach to a worn CV joint . . . changing the joint and replacing the boot, or just getting a replacement axle?  It's the outboard joint on the driver's side axle.
Also, from time to time it's making a noise and/or has a vibration that sounds/feels like a wheel bearing starting to go bad.  A few times it has jerked to the left like the driver's side wheel bearing grabbed.  Could this be because of the CV joint?  The boot is cracked and the joint has some wear, so I'm going to replace it regardless.  With the car on jack stands the wheel bearing seems OK (turns free, no excessive play, no noise, etc.) but I don't really think the CV joint is the source of the noise/grabbing problem.  The few times it's done this, the wheels were straight.  It never makes the noise or grabs or has the vibration when the wheels are cut.
I've change the front wheel bearing on a Fox . . . is the New Beetle about the same process?
Anyone have any advice for me?  VW Boy?
« Reply #1 on: December 09, 2002, 01:10:29 PM »
I haven't had a New Beetle problem with a CV (yet), but I have a habit of buying cars with FWD and about 100K miles, so I've had my share of CV issues.
I look at it this way: BOTH CVs and boots on the axle are the same age, so when one goes, the other usually isn't far behind.  Also, whole axle assemblies aren't usually that much more expensive than 2 CV kits.  Also, you only crawl under the front end once, and you don't have to pull the joints apart (we all know from our old VWs how messy that is).  You usually wind up pulling the whole axle, even for just one joint.  Sooooo, there's my $.02
I'd also bet the CVs where your jerking issues are coming from.  Of course, for a lot of FWD cars you wind up just about taking the whole hub apart to pull the axle anyway, so it may not take much more work to replace the bearings, just to be safe.  They're as old as the CVs too, aren't they?
Have towels handy!
« Reply #2 on: December 10, 2002, 11:50:32 AM »
I'm surprised they have lasted this long, Zen. We all know how Justin drives.            LOL!!!!!!!!!
        :cool:
« Reply #3 on: December 10, 2002, 07:35:47 PM »
All I can say is that a New Beetle MUST be a VERY WELL BUILT car . . . this one was totaled then rebuilt before he bought it, and he's be driving (abusing) it for 2 or 3 years.  And still, overall, it's a fairly nice car!
Joe Kirtpatrick has ordered him a CV axle . . . I guess we'll try that first.  If the wheel bearing is anything like the one on the Fox, you don't want to change it unless you have to.  On the Fox, the whole strut assembly had to come out of the car and be taken to a hydraulic press.
