Topic: Need something like this ...  (Read 2842 times)
Offline Tommy Franklin
  • Ringgold
« on: September 29, 2011, 08:33:20 PM »
While changing oil, I noticed the nut that holds the oil plate on was VERY loose ... Trying to tighten it, I knocked it off ... Anyone know wheres I can get a tool like this :
Or an idea on how to put the nut back on ?!
« Last Edit: September 29, 2011, 09:17:19 PM by TommyFranklin »
Re: Need something like this ...
« Reply #1 on: September 30, 2011, 01:30:45 AM »
That looks like someone took a 12 point box end and cut it, rewelded it at a 90 degree angle and then ground down the sides to be flat. Wouldn't be hard to make if you can weld and grind!
« Reply #2 on: September 30, 2011, 06:04:03 AM »
What Nick said....
I am a former tool dealer, and I love to browse the catalogs of all the manufacturers.... I have never seen one that looks like that out of the box.
And, FYI, you would probably need to have a spare case laying around so you could actually measure, and form the wrench.  Trying to do it in the car, engine assembled seems like a good way to waste a number of hours, and still not get it quite right.   ;)
« Reply #3 on: September 30, 2011, 10:54:27 AM »
To bad you don't have a 36 hp Matra oil cooler wrench used when the #s 3-4 jug cover is left on. It comes pre-bent. 14mm on one side for changing a fuel pump 36 hp only, 10mm on the other end for cooler You just use it upside down. Pretty rare tool today.
  • Ringgold
« Reply #4 on: September 30, 2011, 06:34:39 PM »
I managed to find s 10 mm in my tool box that was so think I could bend in it real easy ...  I ground down the sides and BINGO !  Problem solved ...
Offline IntrstlarOvrdrve
« Reply #5 on: September 30, 2011, 07:22:31 PM »
Kind of looks like a distributor wrench
« Reply #6 on: October 01, 2011, 06:22:37 AM »
Looks good and it looks a lot like that cooler wrench I have  8) 8)
« Reply #7 on: February 24, 2012, 07:05:03 PM »
I think I have seen a set of ratcheting wrenches that actually have a bend at the end that would allow you to get a similar shape, though the ratcheting mechanisms generally make it a little larger.
