Topic: more grease and hello  (Read 8363 times)
« Reply #15 on: October 24, 2004, 04:45:43 PM »
Here's some heaters you might consider.  Both use the small disposable lp bottles (they are sold as disposible, but they can be refilled!).  It might be possible to adapt the "Mr. Heater" to run off your existing tank, but I wouldn't even think about trying to rig up something with the Colman model.
http://www.walmart.com/catalog/product.gsp?product_id=1603296#long_descr
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=41987&item=5928624816&rd=1
Candace
« Reply #16 on: October 24, 2004, 05:51:08 PM »
I like that the Mr. Heater has a carbon monoxide detector. That's a good thing. And it's not a bad price either. Yet.
How long would the alternate battery last if I plug a little electric heater into the 110 outlet? Would it just suck up all the juice making two days of heat cost the price of the battery? I have a little electric fan heater, but the alternate battery is dead. It has been dead since I bought the van. I didn't know if it would be worth it. What you think about that?
« Reply #17 on: October 24, 2004, 07:00:31 PM »
I used a small elecric heater at the Dead of Winter campout (Cloudland Canyon State Park, mid Feb.) two or three years ago.  It kept the temp. in the bus at around 60 degrees even though it was about 20 outside.  It probably would have kept the bus toasty if it had decent door seals and a few less rust holes in the front floor.  But, I was hooked to 110 at the campsite.  An electric heater is probably the best choice as long as you've got an electrical hookup.
I've run my key machine all day long using an inverter hooked to the battery and still had enough jucie to start Homer the Superbus (my world famous Type 1 powered 73 bus).  I don't have an auxillary battery.  BUT, a heater pulls a whole lot more juice than a small key machine motor.  I don't think a battery would last too long running a heater without the engine running.
Kyle and Betty use a Mr. Heater in their Vanagonagon (if someone thinks your door idea is impossible, they should see the Vanagonagon! . . . see picture below).  If it'll heat the Vanagonagon, it should turn a "normal" bus into an oven!  I think they bought their Mr. Heater at Wal-Mart for under $100 . . . I couldn't find one on the Wally-World web site though.
Candace
« Reply #18 on: October 24, 2004, 08:11:48 PM »
Wowee, you've practically got a studio apartment there. I'm liking the idea of the Mr. Heater.
Thanks for the advice!
« Reply #19 on: October 27, 2004, 11:44:52 AM »
If you're not using the propane tank for anything else, it would be sweet to hook up a RV-style heater to it and mount it on the wall or bulkhead behind the driver's seat.  You could start at Northgate RV on 153 and see what they have.
I keep an electric heater plugged in inside the bus and on cold mornings, go out 30 min. before time to go and plug the outside outlet in.  By time to leave, it's comfy.  Then the stock heat can usually keep up.
An alternative to POR-15 that I swear by is Extend by Permatex.  Get it at any parts store for $5 a bottle, get rid of loose rust powder and flakes, brush it on, paint over it or not.  It does the job as well for a fraction of the price!
Candace
« Reply #20 on: October 27, 2004, 12:49:06 PM »
Really? I did come across that at Ace Hardware. But I just didn't know how well it would work. I'd rather not do this more than once. But you're right, the POR-15 IS expensive.
So would I have to completely sand the surfaces down to shiny metal before applying the Extend or just knock off the big chunks of bubbled paint and rust? And would I be able to come back later and fill it in with bondo? There are only a few sections that need serious filling. Most of it on the surface, or just right under the paint.
And how careful would I need to be about getting it on the rubber window seals?
Candace
« Reply #21 on: October 27, 2004, 12:49:54 PM »
Good idee about the propane. I'll check that out.
