Topic: modern fuel in a classic VW  (Read 23536 times)
Re: modern fuel in a classic VW
« Reply #15 on: April 05, 2015, 05:55:58 PM »
Speaking from experience . . . there's nothing quite like the feeling you get when you look in the rear view mirror at a stop sign and see flames coming from the louvers in the deck lid.  Especially if the only reason you bought the car is because it had it's original SunBug emblem on the deck lid and realize it's made out of some kind of plastic.
A few years ago, I got to thinking that someday they would take down all the old Google Groups pages . . . so I copied all of Bob Hoover's "Tulz" series post.  Now I've just got to find 'em on my hard drive.
Offline PapaKoch
  • Treasurer
  • East Ridge, TN
« Reply #16 on: April 05, 2015, 07:26:08 PM »
I'm glad everyone chimed in on the fuel filter between the pump and carb. Seeing the filter there always made me nervous. Now I know why. At the risk of this turning in to a show us your fuel filter thread, I snapped a picture of the fuel filter on Butters earlier today. This one must be 1.5-2 years old and still seems fine. It sits directly under the tank and it is the only one I have on the bus. On a beetle, it seems good to put it by the transmission as long as it does not hang down and rub on the axle. Since they are only $1.00 at a show, might as well change what you have at the first thought of it giving you problem. Why risk it.
« Last Edit: April 05, 2015, 07:34:24 PM by PapaKoch »
« Reply #17 on: April 05, 2015, 10:18:57 PM »
The BEST place to put a fuel filter on a Beetle is between the tank and the tunnel.
Use a quality metal cased filter, mount it on a bracket fastened to the passenger side of the firewall . . . you may have to pull the passenger tire to replace it, but your risk of it ever causing a fire just dropped to nearly nothing.
But still carry a fire extinguisher or a bag of marshmallows.  IF it catches on fire, you either need to put it out, or put it to good use (that's what the marshmallows are for).  Just my opinion.  Everyone is entitled to their own.
Offline Got Bug ?
  • Chattanooga, Tn
« Reply #18 on: April 05, 2015, 10:21:04 PM »
I had a '62 that caught fire because the inlet nipple at the carb pulled out without a filter to help it along. Not the hose from the nipple, but the nipple from the carb body.
After that adventure I invested in a few clamps and some safety wire.
« Reply #19 on: April 05, 2015, 10:28:06 PM »
Good point!  It CAN happen without the filter . . . but it happens a LOT more often with the added weight and vibration from the filter.  Safety wire is DIRT CHEAP INSURANCE that everyone should use, with or without the filter!
By the way, I've just uploaded a pdf file of Bob Hoover's Tulz series in the pinned Bob Hoover thread.  Everyone who drives an air-cooled VW should read his section of "FIRE" . . . it's good!
« Reply #20 on: April 06, 2015, 12:45:07 AM »
Like I said before, I replaced Bonnie's fuel line last summer or so. When I did, the tank came out and got a decent cleaning (it had already been boiled at a radiator shop). I had read before that if you fuel outlet threads get stripped, you can actually tap the inside of the outlet for a brass nipple. I went this route, but used a 90 degree fitting with a shutoff valve THEN the nipple. Now, if I need to change the fuel line, I can turn the wheel shut the fuel off, run it dry and proceed.
Or I can run the engine dry if I want to service something or park it for extended periods again.
« Reply #21 on: April 06, 2015, 12:46:27 AM »
Safety wire fix:
Offline cristie
  • Calhoun
« Reply #22 on: April 07, 2015, 07:03:28 PM »
Happy dance. . My manual came in!   It used to be a library book. .. appropriate! !! Next step,  tools :) life rocks.  :vw:
« Reply #23 on: April 07, 2015, 07:31:25 PM »
That's one of the good ones!  It is a new enough printing that it has some info on Things, Type 4s and Fuel Injection . . . but old enough that it's still spiral bound.  The new printings are no longer spiral bound and you can't open them to page and lay 'em flat while you are working.  When you take your hands off the book the new ones want to close, or at least flip a few pages.   8)
« Reply #24 on: April 07, 2015, 07:33:14 PM »
The newer editions even include an appendix that shows you how you can saw off the spine, punch holes in the pages, and insert them into a large three-ring binder.
Offline cristie
  • Calhoun
« Reply #25 on: April 07, 2015, 07:57:20 PM »
Yea, I've owned enough sketch books in my life to know spiral bound is the only way to go!
Offline cristie
  • Calhoun
« Reply #26 on: April 08, 2015, 12:40:42 PM »
http://community.cartalk.com/discussion/2146815/how-do-you-know-if-you-are-buying-ethanol-free-gas
I found this thread talking about fuel.  Super awesome if you are like myself and need things broken down before I can ' get it'
Russ, you mentioned not believing if the gasoline is actually non ethanol. .. this testing option seems doable!
July 2010 edited July 2010
Put a small amount of pure water in a test tube and mark the amount with a line on the test tube. Now fill the test tube the rest of the way with the gasoline you suspect contains ethanol. Put a stopper on it and shake well and allow it to sit until the gas and water separate into different layers.
If the water layer is higher up the side of the test tube than it was before you added the gasoline, the gas contains ethanol, the ethanol goes into solution in the water layer and adds to its volume. Ethanol is the only commonly used gasoline additive that is highly water soluble.
0
meanjoe75fan Junior Grease Monkey
100% correct.
I checked out this thread to offer just this advice, only to see I was beat to it! (Since I can't claim "what to do," at least let me chime in with "why it works"):
"All solvents are either "polar," "non-polar," or some combination. Polar substances are "water-soluble"; non-polar are "oil-soluble."
Alcohol is a mix: the non-oxygenated side is non-polar (making it miscible in non-polar solvents), and the end with the hydroxyl is polar (making it miscible in polar solvents such as water, as Dean Martin can attest).
What you are doing with the "test tube" test that B.L.E. mentions is forcing the ethanol to choose between the water and the petroleum (polar and non-polar solvents, respectively, that won't mix). Apparently, ethanol is somewhat more "polar," on net, than it is "non-polar"...so it transfers to the water portion.
Offline Got Bug ?
  • Chattanooga, Tn
« Reply #27 on: April 10, 2015, 06:50:07 PM »
Yeah...what he said...
Years ago some folks added a bottle of rubbing alcohol to their tank once in a while. The story was that if you had water in your gas tank, the alcohol mixed with both water and gas and allowed the water to be dispersed throughout the gas instead of sitting at the bottom of the tank. Nice idea. I tried mixing water and gas in a test tube. It wouldn't mix. I added rubbing alcohol and prepared to be amazed.
I couldn't tell that anything happened. I think the alcohol mixed with the gas, but the idea that the alcohol could then absorb the water was only wishful thinking.
I did learn that if you think you have water in your tank...drain your tank!
Offline cristie
  • Calhoun
« Reply #28 on: April 13, 2015, 09:53:20 AM »
That kinda made me laugh. Sounds like something that would happen to me.  I'm pretty sure if/when i test it. ..nothing will happen.  Loads of anticipation. .short outcome. Ha!!!!
