Topic: Mirror Installation Help Please  (Read 3131 times)
Offline davie914
  • Nashville
« on: February 02, 2011, 06:06:15 PM »
Hey now, looking forward to BugAPalusa
Dave from Nashville here, wanting to install a passenger side view mirror in my 74 standard beetle.  I have a mirror from empi but realize I need the insert it screws into since the car didn't come with one.  Anyone know where I might get such an item,  Thanks  Dave
Re: Mirror Installation Help Please
« Reply #1 on: February 02, 2011, 06:37:31 PM »
Beetle convertibles had passenger side rear view mirrors, you could find a door from one and use that as a donor to weld in.
Just to understand.... you mean that you have no mounting hole there, correct?
Offline davie914
  • Nashville
« Reply #2 on: February 02, 2011, 07:48:32 PM »
Yeah it never had a passenger side view so no hole and nothing to thread it into, I think they are roughly 16 mm fine threads but not perfectly sure
« Reply #3 on: February 02, 2011, 08:23:00 PM »
Otay, then...
Yeah, like i said, you could get a donor chunk from a convertible door, but i doubt you could buy just the section from anybody, prob. the whole door, and, if you shipped it, that would get pretty pricey.  Or.... you could just make a plate using a large nut welded to flat steel, mount that into the door.  You would have to cut a "window" on the outside, make the inner structure, then weld the outer layer back I suppose.
Another alternative would be to just buy a donor driver's side door, cut out the innre section, and adapt it to the passenger door.
Offline davie914
  • Nashville
« Reply #4 on: March 17, 2011, 12:27:50 PM »
You can buy the insert you need from Empi I recently got one on Ebay for about six bucks
