Topic: Loose Steering Column  (Read 3079 times)
Offline kkimich
  • Lafayette, GA
« on: September 04, 2013, 08:02:00 PM »
I have a 1966 VW Dune Buggy that has a steel rod for the steering column that is not stable. Do they make a bracket to stabilize it or what should I do about it. It drives good but the steering column is loose.
Re: Loose Steering Column
« Reply #1 on: September 04, 2013, 08:15:32 PM »
Sounds like it missing the bearing or it is worn,  maybe more pictures or info would help,
 Does it have a steering column from a beetle or just a rod?
« Reply #2 on: September 04, 2013, 09:05:26 PM »
I'm with Travis . . . a picture or two would be a BIG help on this one.  I've seen some really "creative" stuff people have done putting buggies together.  If it's a just a rod, you could probably get a couple of pillow block bearings that fit the rod and bolt them in place . . . but, for safety reasons, I would consider changing it over to a newer style Beelte steering column with the colapsable "cage" on it.
« Reply #3 on: September 05, 2013, 10:22:44 AM »
I have a late model with collapse section for $15.
Let me know.
706-980-5313 in Ringgold south area.
« Reply #4 on: September 07, 2013, 07:43:24 PM »
Empi used to offer a bearing that was installed into a carrier bracket that could be bolted up under a rail/under a dash of a fiberglass dunebuggy.  The center rod of the column passed through it, no outer tube needed.
