Topic: little brass wire on inside of Dist - nut that holds the condensor in place  (Read 3053 times)
Offline eakanator
  • Rome, Ga
1970-Beetle. The condensor is held in place by a screw that runs thru the dist, which then attaches to a nut. The nut has a wire on it, The other end of the wire is not attached to anything. should it be soldered to something inside the dist?
Ron
If it's the wire I think you're talking about, it should be attached to the points plate (assuming you have a vacuum advance distributor).  If it isn't, your points will have a poor ground at best, and without the points being grounded, your ignition won't work.  If you've got electronic ignition it might not matter . . . since I'm a "do it the cheapest way possible" kind of guy, I don't know much about how those electronic ignition modules wire up.  If it's a 009, the points plate doesn't move and is fastened into the distributor body by small screws and doesn't need the ground wire.  If that's the case, I don't know what wire your talking about, so ignore my ramblings . . .
 :D
Edited By Zen on 1088355613
Offline eakanator
  • Rome, Ga
Thanks Zen, That's excatly what I'm talking about and please by all mean (which I don't consider it rambling) But if I can learn by all means don't stop, at least to the headache point, but that's because that's all I can comprehend in one day.
Ron
Zen is correct . You told me .I think, that you have a vacumn dist. The wire is brazed to the point plate. if you look closely , you can see where it was connected. I have seen all kinds of fixes here. Trying to solder, Drilling a hole/tap, running a new wire over to the screw holding the points. If you use a new wire,It needs to be a braided wire so it will flex when the plate moves. Try to fix it if you can. See if you can get someone down there to "spot it' for you. I have seen it done.
Offline eakanator
  • Rome, Ga
It is the vacum advanced unit, I wonder if a person could also use the JB Weld or a so called "liquid metal" that some places sell. I put the soldering iron to it, just as you think it held, not much pressure for it to knock it loose.
Ron
JB Weld is great stuff, but it's an epoxy.
Whatever you use for your repair has to do two things.  First, it has to mechanically hold the wire to the plate and stand up the heat an vibration of the engine and the constant movement of the points plate.  JB Weld will probably work for that, BUT . . . will it conduct electricity?  That's the big question and I have no idea.  Remember the purpose of the wire is to give your points a sure path to ground.
Offline eakanator
  • Rome, Ga
your right and agree I think it may hold, but I dont think it would conduct. I even ruled out the wife's picture hanging braided wire becuase of that. I'll call around after while when everything opens up, but don't feel like Auto Zone or Advanced will have anything. Would mind as David metnioned, soldering another piece of braided to the existing one and attach to the points screw.
Ron
I tried the JB Weld on another application hoping it would conduct electricity and it will NOT. :(
