Topic: Line Boring  (Read 4029 times)
Fukkenwalken
Line Boring
« on: May 16, 2008, 12:16:13 PM »
Anyone know a good machine shop that line bores aircooled VW engines. Also need the heads worked over and a "dry fit" of the short block for clearances etc.... I live in Knoxville but I have a non-VW that will make the trek to Chattanooga if necessary.... I would prefer a Knoxville based shop.
Any help or advise  would be greatly appreciated.....
-B
Line Boring
« Reply #1 on: May 16, 2008, 03:17:29 PM »
I can linebore your case and do your heads.  I'm not clear on what you mean "dry fit" for clearances.  Im a retired factory trained VW tech after 45 + years on aircools. I work at my home.
     I,m in Chatt.    If you can't find someone closer to you I'll will be glad help you out.  You can P.M. me or call    423-894-3374
     David
Fukkenwalken
Line Boring
« Reply #2 on: May 16, 2008, 06:13:42 PM »
Thanks....I may take you up on that....   What I mean by "dry fit" is-  to fit the cam and crank and bearings and lifters, etc...  To make sure they all fit properly....
Once again thanks....... Anyone know a good shop a little closer to K-ville....
I don't mind to drive there but with the way fuel prices are...
Offline IntrstlarOvrdrve
Line Boring
« Reply #3 on: May 17, 2008, 01:35:08 AM »
Not to threadjack, but what does a line bore typically run?
Fukkenwalken
Line Boring
« Reply #4 on: May 17, 2008, 10:43:51 PM »
I've never had one done.... I've always bought the cases "ready to assemble".   I'm sure it's cheaper than a new or reman case..... Judging buy having head work done, it shouldn't be too bad.....
Fukkenwalken
Line Boring
« Reply #5 on: May 17, 2008, 10:47:08 PM »
Dang..... Wrong photo....
Just got these out of the hot tank.....  One more dip.....Then, off to the shop for a little machining.... I wish I had the equipment to do it myself....
Line Boring
« Reply #6 on: May 18, 2008, 11:20:36 AM »
Cost can vary. Somewhere between $ 50 to $65 depending what has to be done.  With the price of new cases being just about "Out'a Sight" I belive a person needs to look at trying to save their orignal case if at all possible or go for a GOOD reman. case. You would be surprised how many cases get tossed when they could have been saved.
     If you are going to build a big "Bad Ass" engine ,I think I would go with a new case thats been prep for it.  Its just money.
     I have had "0" problems with boring as long as the case is not warped though the main bearing journals or cracked somewhere.  This you can check before doing anything.
Fukkenwalken
Line Boring
« Reply #7 on: May 27, 2008, 11:59:58 PM »
I'm still not having any luck..... I may have to come down there.....
I'm gonna try to get a few items ready for the shop...
I'll be in touch
Line Boring
« Reply #8 on: May 28, 2008, 04:49:28 PM »
If you come this way be sure to let me know when. I can also do your cly.heads.  I'm home 95% of the time.
Line Boring
« Reply #9 on: May 28, 2008, 05:13:13 PM »
That is until Albert de Allison is finished, right!?  Then you will be cruising the Scenic Hwys! 8)  :lol:
Fukkenwalken
Line Boring
« Reply #10 on: May 28, 2008, 10:37:08 PM »
I'll let you know for sure...  Can you do the clearances for 90.5mm pistons?  Along with the heads?  1776cc
-Brad
Line Boring
« Reply #11 on: May 29, 2008, 11:19:23 AM »
No sir .    Stock stuff only.   Been there ,done that.   I'm not getting involved anymore in modifieds.  To much trouble.
Fukkenwalken
Line Boring
« Reply #12 on: May 29, 2008, 11:28:09 AM »
Just thought I would ask... I'm also building a 1776cc along with a 1641cc....
