Topic: LED tail lights  (Read 3901 times)
LED tail lights
« on: June 05, 2012, 11:31:13 AM »
A couple of years ago, I ordered a couple of red LED bulbs for the brake/tail lights on the bus from superbrightleds.com. They seemed to work fine when I installed them, but lately I had people tell me my brake lights would come on randomly. I even noticed that parked in the garage, if I turned the key, my brake lights would be on without turning on the lights or hitting the brake pedal.
Thinking that a bulb is a pretty simple thing even if it's LED, I thought I might have electrical gremlins causing my lights to go off. After all they shouldn't be on without voltage applied to them.
Before digging too deep though I swapped the LED bulbs out for traditional bulbs and the problem went away. Brake and tail lights work just as they should.
I guess I'll keep them that way from now on, I was hoping the LED bulbs would be brighter and more visible but it's no good if they are just going on and off randomly.
Re: LED tail lights
« Reply #1 on: June 05, 2012, 04:24:42 PM »
Kinda sounds like a bad brake light switch
Re: LED tail lights
« Reply #2 on: June 05, 2012, 04:58:30 PM »
Brake light switch is fine. When I swapped in the regular bulbs, it all worked again.
Re: LED tail lights
« Reply #3 on: June 05, 2012, 10:48:57 PM »
LED's take less energy to "glow" than a bulb, your brake switch could be grounding just enough to light the LED's but not the bulb, since the filaments have to heat up to glow...
I think I'm right in this...
Re: LED tail lights
« Reply #4 on: June 05, 2012, 11:01:48 PM »
What he said. Sounds reasonable.
Time to pull out the free multimeter from harbor freight!
Offline Essdaw
Re: LED tail lights
« Reply #5 on: November 20, 2012, 10:41:02 PM »
Thinking that a bulb is a pretty simple thing even if it's peimar led lights, I thought I might have electrical gremlins causing my lights to go off. After all they shouldn't be on without voltage applied to them.
You might have got low quality LED lights otherwise it would not have happened
« Last Edit: November 21, 2012, 01:13:18 AM by Essdaw »
Re: LED tail lights
« Reply #6 on: November 21, 2012, 08:30:00 PM »
You might need to add a resistor to the circuit so that "off" is really "off".  We made some stink bug traps 2 months ago and the cheapo l.e.d. tap lights that we used are still putting out light even though they've been on for 2 months straight.  Granted, they aren't bright but they're still on.
Oh, and clean your grounds.   ;)
