Topic: Kemco Octane 130 Supreme  (Read 3793 times)
« on: January 18, 2007, 12:00:21 AM »
This email was sent to the club . . . anyone want to voice their opinion?
Sent: Tuesday, January 16, 2007 7:26 PM
To: info@volksfolks.org
Subject: [Volks Folks] Kemco Octane 130 Supreme
Hi Everybody,
I have a 1973 Westy stick shift with the pancake engine (1700).  I have been using 93 Octane gas with no problems.  What are your opinions about using a lead additive such as Kemco Octane 130 Supreme as far as whether it is good or not for the longevity of the engine life?  Or should I stay with the 93 Octane?  Thank You!
Gregg Scott
Re: Kemco Octane 130 Supreme
« Reply #1 on: January 18, 2007, 09:01:55 AM »
Quote from: "Zen"
Hi Everybody,
Gregg Scott
How about....
Stop wasting money and use 87 like you're supposed to!   :shock:
sorry, couldnt think of a nicer way to say it!
« Reply #2 on: January 18, 2007, 12:37:55 PM »
If your engine has ever been rebuilt,chances are that stuff will do more harm than good.Most modern piston/head combo's are ste up to run normal/modern gas. I wouldnt chance it if your runnin good on 93 stay with it. The risk of burnt valves and cyliders from prolonged use of the additive isn't worth the small gains you may or may not see.
Just my 2 cents worth.
« Reply #3 on: January 20, 2007, 09:32:27 PM »
Feel free to use the higher octane stuff, it's better quality, burns cleaner, and does offer better performance (that you can feel with a 200hp engine...I don't know that you'd notice anything with the 75hp/under category), although it isn't really necessary.
As for the lead additive stuff, I personally would not bother as I haven't seen any advantage to using that stuff in anything other than some old Detroit gas hogs.
« Reply #4 on: January 21, 2007, 10:46:55 AM »
please explain how it is better quality? Are you talking about the fuel companies putting more additives in the premium fuel? the additives have been regulated by the government so you are not getting anything extra except the additives that change the octane rating
The octane rating is based on the fuels ability to be compressed before it ignites. Therefore if you have a higher compression engine then you would raise the level of octane you are putting in to your vehicle in order to prevent pre-ignition or knocking.
If you have a carburated vehicle then you should try tuning your carburator and checking your timing rather than masking your mistuning with a higher octane fuel... it will save you the cost of the extra $0.20/gal on the unnecessary higher octane rating.
If your vehicle is fuel injected, then the computer is designed to control the delivery of the fuel based on the manufacturers specifications of the fuel rating. By buying a higher rated fuel you are doing a couple of things:
1. paying the fuel companies extra money you could be giving me for advising you of the waste
2. sending unburned fuel in to your catalytic converter to clog it or sending the unburned fuel out the tailpipe
It's your vehicle and your money. I haven't bought premium gas since I stopped driving my 1776 dual carb high compression super beetle. I've saved myself several hundred dollars by using the fuel VW specified for my vehicles.
Offline 98GTI
  • President
  • CLEVELAND. TN
« Reply #5 on: January 23, 2007, 03:19:50 PM »
:o WOW! :shock: VWGirl did you research this issue or is it posted so elequently that you just snow-balled all of us?
