Topic: IRS Transaxle  (Read 1901 times)
IRS Transaxle
« on: October 15, 2009, 05:37:19 PM »
Well I am ready to start clean-up on my transaxle so that I can install it on my pan.  Before clean-up began, I decided a good visual of the outside would be a good idea.  I noticed that the nose cone, the axle output shaft and the input shaft were all leaking.  As I was draining the transaxle the fluid smelled burnt and there were some metal shavings on the magnetic drain plug.  My questions are....is it feesible to disassemble and replace the seals without special tools?  Who in the club is the transaxle expert (notice I did not say tranny)?  And if I have someone tear into this thing to replace seals and they find more probs, is it less expensive to purchase a new unit or rebuild the one I have.  Thanks.
J.R.
IRS Transaxle
« Reply #1 on: October 16, 2009, 08:32:11 AM »
J.R, Check your P.M.
IRS Transaxle
« Reply #2 on: October 16, 2009, 09:28:34 AM »
Send it unto the Godfather.  Do not pass go, do not collect $200....
 8)
IRS Transaxle
« Reply #3 on: October 16, 2009, 09:29:38 AM »
Give me a call JR.... forgot to call you back about the axle.  leave me a message if i don't answer, I'll call you back.
 :D
IRS Transaxle
« Reply #4 on: October 16, 2009, 09:43:01 AM »
Will do Rick.
