Topic: Interchaingable parts years ?  (Read 1901 times)
Offline Roadkill
  • Ooltewah Tn.
« on: September 09, 2010, 03:25:45 PM »
Just a quick question. Wanting to know what years of parts are interchaingable with a 1974 standard beetle. Not really any certain parts but just a general overview. I will be needing a good number of interior and engine parts as i figure out what goes on the " I need this list ".
Re: Interchaingable parts years ?
« Reply #1 on: September 09, 2010, 04:31:15 PM »
Hard to say. There are a lot parts you can use. Best when looking for a certain part then you try looking and asking and comparing . ???
« Reply #2 on: September 09, 2010, 08:52:17 PM »
So true.  There is actually nothing quick or simple about that question...
I agree with David, give more specifics and we can help narrow down the playing field for ya.   ;)
« Reply #3 on: September 09, 2010, 10:19:07 PM »
From 1968 up, you can pretty much interchange any parts with any years . . . however, if you change one part, a lot of times you might have to change two or three others to make everything fit/work correctly.  For instance, in the interior, if you buy new door pannels, they will fit any 68 or later Beetle, but the arm rest changed somewhere along the line.  We installed an earlier driver's door on Justin's 74 super many years ago and everything swapped over from the 74 door to the older door, but we changed the arm rest to the earlier style rather than try to install the plastic pieces the new style arm rest screwed in to.  The only problem was we had the new style arm rest on the other door . . . so we cut out the metal tap that holds the old style arm rest strap from another old door and rivieted it on the 74 door so we could use old style arm rest on both sides.
As for complete engines, just about anything from 67 and up will interchange, but you can't bolt the intake off a 67 on a 74 engine 'cause one is a single port and one is a duel port.  You can put the engine from a 79 fuel injected Super Beelte convertible in your 74, but you will have to convert it to a carb and install an electric fuel pump . . . and I don't think the head tin will fit, so you'll have to use the non-fuel injected tin . . .
Lots of little things changed from year to year so like Ret.Bugtech and cetdubtech said . . . it's hard to say & there is no quick or simple answer to that question.  It pretty much has to be a part by part question.
Offline Roadkill
  • Ooltewah Tn.
« Reply #4 on: September 09, 2010, 11:27:36 PM »
Thanks for all the information. This will help sence i am the new owner of KC's Love Bug he had. There is a lot of work to be done but i am having fun. I will need all the seats and a couple panels for the interior and a few other things for it. I will be picking up the engine this weekend so i will have a list for everyone then and probably find some one to put it together....... ;D. I will also need to replace the floor pans so i will need to find a person for that also sence i really do not have the place to do this. I am skirting the rules of my comunity by just having it in my driveway at this time. Later when i have the list ready................Rob
