Topic: Hydrogen Generator on an Air Cooled Engine  (Read 13725 times)
« on: September 15, 2014, 05:01:14 PM »
Soooo..... a buddy of mine has a son who is about 15 years old and in high school. He is doing a sort of science project that is a little more than science fair type thing. He has access to a 3-D printer and they have a fabricator that will help with particular parts that aren't readily available.
I went my high school football game last Friday and ran into them. The student began telling me about how he was going to build a "Brown gas motor." I later found out that this is another name for the hydrogen generator on a gas motor. He began telling me that he still needed to get everything set up through the teacher and if she can't find him an old vehicle to work with, he would end up using his dad's old tahoe. I told him I had a VW 40hp air-cooled motor sitting in my garage and if we could go through it and re-seal it/clean it up, I was certain that it would run. I told him I even had a test stand that we could use to try it out without having a full car.
Today he texted me and said that he was willing if I was, so it looks like I'll be rebuilding a 40hp and making an attempt at it.
My goals:
- Get a running 40hp at the (beginning and) end of it all.
- Minimize damage to the engine I currently have.
- Convert it over to 12 volts.
- Help this kid get hooked on air-cooled VWs early
- Maybe have neat display at Bug-A-Paluza next spring.
My Concerns:
- Running an air-cooled engine on hydrogen and the heat
- That a 40hp will be harder to manipulate than a 1600
- Converting it to 12volts
- That I ruin his Science project with a VW engine.
If all goes well, I might even swap it out for the engine in Bonnie and do some "real world tests" for him.
I already know what Zen is going to say: "Put a relay on the generator so that its not pumping hydrogen into the intake of a non-running engine...and then you get in a fire it off!" Apparently, Ted did this and it cost him an air cleaner box and a straight hood!
Does anyone else have any thoughts on this science project?
« Last Edit: December 11, 2014, 12:12:42 PM by volksnick »
Re: Hydrogen Generator on an Air Cooled Engine
« Reply #1 on: September 15, 2014, 10:47:13 PM »
The amount of energy it takes to create Brown's gas from water is slightly greater than the amount of energy it contains.  Brown's gas is water broken down into hydrogen and oxygen.  It's the perfect fuel.  Burns HOT and FAST and completely.  The only byproduct is pure water.  It's probably impractical as a stand alone fuel but you don't have to dump a whole lot of it into the intake to make a significant improvement on gas milage.
The big thing is you can't let the hydrogen accumulate anywhere it might be exposed to a spark.  Remember the Hindenburg.
« Reply #2 on: September 24, 2014, 02:25:32 AM »
I broke it down tonight and split the case. I have one set of rockers, the pistons and cylinders look serviceable so far (new rings), heads look serviceable but I have 3 extra if needed, I have a good oil cooler, intake and exhaust. Picked up a 40hp bus muffler at SAP for $30!!!
The crank and flywheel look to be the early ones... I need to figure out how to put a 12volt flywheel on this one. Any ideas?!?
There don't appear to be cam bearings. I guess this is ok? They don't look bad. Does the 40hp use the same cam as all the others?
Cleaning everything up in the next few days and then seeing what all I need to track down.
« Reply #3 on: September 24, 2014, 02:44:11 AM »
I think the later 40 horse engines used cam bearings. Before that, the cam just ran in the case.  I had the oportunity to buy a line boring kit at the first Birmingham Bug Blast, but it sold before I could get to a teller and back with the cash.  It included a tool to cut the case for cam bearings.  But, if it doesn't have bearings, it's probably not a problem.  I'm 99.9% sure the cam stayed the same with or without bearings.
I've changed a couple of engines from 6 volt to 12 volt and 12 volt to 6 volt.  I don't recall what all you have to look at to firgure out if you need the o-ring or gasket to seal between the crank and flywheel.  I always just asked David.   :(  Maybe Rick or someone else out there can tell you.  William might know . . . but you'll have to call him.  He don't get on the 'puter very often.
« Reply #4 on: October 24, 2014, 01:38:04 AM »
Started reassembly the other day. I got the short block put together and forgot the gears for the oil pump, so I had to take the cover off to get them in. I went to put pistons/cylinders and heads on tonight, but I ended up breaking a ring. Turns out the ring compressor I have says it will do 83mm pistons, but it won't! I have it mostly closed up now with the heads loosely installed to keep everything somewhat covered. One day it will look nice!!!
Do anyone have NOS 83mm piston rings?!?!
And a distributor clamp?!
« Reply #5 on: November 26, 2014, 02:26:31 AM »
It has gone together really well so far. I only lack a 6volt starter and the terminals that bolt on to the coil for the push on connectors. Stupid new coil came without them. Anyone have an extra coil that is bad that would let me rob those?!?!?
It's starting to shape up!!!
« Reply #6 on: November 26, 2014, 06:59:58 AM »
I'll check
« Reply #7 on: November 26, 2014, 07:35:53 AM »
Looks clean!
« Reply #8 on: November 26, 2014, 08:15:32 AM »
Also, I have a stale air bus exhaust. It was cheap so I got it. I went to put a pea shooter in the one hole and the pea shooter is to big around to slide in! Did they make two sizes?!?!?
« Reply #9 on: November 26, 2014, 03:23:30 PM »
I'm not sure if the pea shooters came in more than one size, but I'm pretty sure the bus exhaust pipe was slightly smaller than a pea shooter.
« Reply #10 on: November 26, 2014, 05:26:23 PM »
That makes sense. I don't think I'll fork over the money for the correct tail pipe just yet. I think the 3/4 female to female rigid conduit adapter will fit fine with a 6" piece screwed into it!
« Reply #11 on: December 07, 2014, 11:10:23 PM »
Holy Carb Spacer, Batman!!!
Charging the battery for a test fire!!!
« Last Edit: December 08, 2014, 02:38:19 PM by volksnick »
« Reply #12 on: December 08, 2014, 06:00:21 AM »
Looks nice
« Reply #13 on: December 08, 2014, 11:33:43 AM »
I have a bus vaccume adaptor off of the '70 that was for a SP that looks almost identical to that (only 3/4" thick), I am looking forward to seeing this work.
If so I may put one on the ghia...
Offline PapaKoch
  • Treasurer
  • East Ridge, TN
« Reply #14 on: December 08, 2014, 12:33:13 PM »
If you ever want to part with that sp bus intake with the vacuum assist port , let me know.
« Last Edit: December 08, 2014, 12:35:38 PM by PapaKoch »
