Topic: Hurst Bug Trigger lock shifter?  (Read 5137 times)
« on: May 18, 2012, 10:25:08 AM »
Hey,
In my most recent acquisition, there was a hurst marked trigger lock shifter simular to the Empi junk now made.  I'll get some photos, but I want to know where I can get the ball that sits on top.  can an empi one be used?
I think I have a wooden one somewhere in my piles of junk that came out of Kermit.
But it is an allen set one not a screw on.
Shifter currently has a screw on Morosey? aluminum T handle shifter top on it.  Talk about difficult to operate a trigger lock when shifting with a t handle...
Re: Hurst Bug Trigger lock shifter?
« Reply #1 on: May 18, 2012, 11:48:18 AM »
Have you checked eBay?
« Reply #2 on: May 18, 2012, 01:56:23 PM »
Hey,
I just love shifters that test and destroy syn. rings in the tranny. I promote using them because I use to make a pile of money on tranny repairs. ;D ;D
« Reply #3 on: May 21, 2012, 03:41:28 PM »
Those shifters have value...
especially to those who are slaves to trends, and not knowledgeable about the wear and tear they do.
If I had one, i'm thinkin' it would have to make it up on the auction block.
« Reply #4 on: May 21, 2012, 09:24:40 PM »
I've ordered a replacement ball for the top.
It really was the diamond in the dung of this beetle I have.
I was hoping that "hurst" was the bomb.
« Reply #5 on: May 22, 2012, 09:26:11 AM »
What kind of damage do Hurst shifters do? My beetle came with one and I haven't thought much about it.
« Reply #6 on: May 22, 2012, 02:37:33 PM »
The shaft that goes into the cup on the shift rod is much shorter(pivot point is moved down) so if you move the shift lever at a normal speed, the lower portion of the lever is going at a much greater speed. Just think what happens when you really throw a shift on the poor thing trying to beat a Vega off the line. The poor syncros are busting their butts trying to keep up with things. A whole lot of syncros die on the spot taking the gear train with them. Another problem is the reverse lock-out doesn't always work right. Talking about re-forming rev. idler into a smooth bushing. It sounds great when that happens.  $$$$$$$$$$$ I love it
« Reply #7 on: May 22, 2012, 02:52:30 PM »
If you really want to feel racey and you are part Monkey(long arms) just saw about 4" off you gear shift lever and you can almost make a cheap Hurst and do just as much damage for the price of a hacksaw blade. OMG !!!!  I hope SC doesn't see this.
« Reply #8 on: May 22, 2012, 03:12:54 PM »
So its not that the shifter damages as much as it allows the driver to mess everything up quicker!
Does the quick shift kit do the same?
« Reply #9 on: May 22, 2012, 04:59:44 PM »
YES .    Even if you drive and shift gears normally , It still put a hurt on the syncro's . Its like trying to speed shift a stock unit. I have seen people shift so fast that the hockey stick will get caught and jamed between the 3 levers and you are STUCK in 2nd or 3rd gear.
« Last Edit: May 22, 2012, 05:05:44 PM by Ret.Bugtech »
« Reply #10 on: June 25, 2012, 10:55:28 AM »
I just put one in the 917, an EMPI with the 9" stick. Shifting it smoothly involves doing what was mentioned above-slow movement pushing it into gear-plus a heaping helping of mechanical sympathy. Feel and listen to when the engine speed is lined up to the new gear and let it slip in. Double-clutch downshifts are a must, as well, so start practicing!
« Reply #11 on: June 25, 2012, 02:47:29 PM »
VW spent a long time/money figuring out what works best. Why do people try to second guess them just to try to look racey ?
« Reply #12 on: June 27, 2012, 04:10:59 PM »
...because at a certain point there's no turning back?
The stock shifter looked like it was giving Steve McQueen the finger. I just couldn't have that.
PS-not my car because, once again, I couldn't get my computer to upload my pic. ??? >:(
 Anyway, take away the orange and decals (which I plan to add) and you've got my car.
Hey, I'm the guy who can pull his FV engine after a racing season and still have paint on the clutch face! Mechanical sympathy-I haz it!
« Last Edit: June 27, 2012, 04:14:53 PM by Anthony »
« Reply #13 on: June 27, 2012, 04:30:33 PM »
HMMMMM, I wonder where we could find one of those cheap 1200 hp  FLAT 12's.  That would be just to cool 8) 8) 8)
