Tech. Center
Air-Cooled VW Tech
How many more miles can get on this tire?
Pages:
Topic: How many more miles can get on this tire? (Read 4900 times)
Smelly_Cat
Re: How many more miles can get on this tire?
Reply #15 on:
March 24, 2010, 05:53:05 PM »
Lugs are too tight. had to revert to plan B
Reply #16 on:
March 24, 2010, 05:59:54 PM »
Ummm . . . no. S.C. - the crack in the tread isn't the problem. The crack is the results of the problem. No matter how well you glue the crack shut, you've still got a bad tire. (as ASBug said "I see dead people." )
I've got 350 pounds of dead weight that isn't good for much of anything else . . . you want me to come over and bounce on your lug wrench and break 'em loose?
swagginjello
cleveland, tn
Reply #17 on:
March 24, 2010, 07:20:42 PM »
not sure what to say about this... id really like a smily face thingy where it smacks it self in the face "doh"...
jrcnova
Soddy Daisy, TN
Reply #18 on:
March 24, 2010, 10:26:18 PM »
I am even more amazed that you were not kidding about putting rubber cement on it. I don't know what more I could say about this without being rude.
bubbz
Scratching my head, trying to fix on this railbuggy!!
Life is good!!
Reply #19 on:
March 24, 2010, 10:31:14 PM »
you need a bigger hammer or longer cheater bar.
I dont do to be cool, I do it because I can!
Smelly_Cat
Reply #20 on:
March 25, 2010, 06:27:49 AM »
Come on everyone, Whats gona happen? I get a flat?, Stupie only goes 45 mph
Reply #21 on:
March 25, 2010, 10:01:31 AM »
Hey forget about the lug nuts. This is what you do. Jack the car up, take the axle off on the side that the lugs are stuck, take the tranny /engine out, have the spider gears welded so you can have one wheel pulling all the time. Then on the side that the lugs are stuck, lock the brakes then strap "Wonder Boys" old skate board onto the tire. Put her back on the ground and off you go until the other tire goes flat. When that happens take the hammer that you were going to beat the lugs off with, hit yourself in the crotch until the Guys in white coats show up and take you back to the "Home"
Last Edit: March 25, 2010, 10:09:37 AM by Ret.Bugtech
certdubtech
In the Garage...
Reply #22 on:
March 25, 2010, 11:09:55 AM »
^^^^ could not have said it better myself.
Reply #23 on:
March 25, 2010, 10:17:55 PM »
Quote from: Smelly_Cat on March 25, 2010, 06:27:49 AM
With "round" tires, Stupie might hit 55.
Pages:
Tech. Center
Air-Cooled VW Tech
