Topic: How bad do I not want a Camper with an automatic trans?  (Read 2213 times)
« on: December 21, 2008, 08:22:11 AM »
Yo Yo,  I have a line on a cheap camper ,  not running with an auto matic in it.  Should I run away or are auto in vans not so bad?    What years did they put automatics in campers?  SC
Offline 74loaf
  • Hixson, TN
« Reply #1 on: December 21, 2008, 05:05:27 PM »
my 74 auto works good, from what I can tell they are pretty reliable, but I'm sure there are problems to be had... it is easier with an auto to get the motor in and out and it is "fun" to get to the torque converter bolts through the tiny window on the block...
When I first started messing with mine, I though I had problems with the transmission since it shifted at very high rpm's and didnt go into 3rd, but I later found out that was just because the vacuum line had come off that goes between the motor and transmission.
The only issue I have with mine now is that it leaks a little transmission fluid around the pan gasket. Otherwise it works great!
Offline swagginjello
  • cleveland, tn
    • facebook...
« Reply #2 on: December 21, 2008, 05:10:39 PM »
spend the money on a good one, or you'll spend atleast twice that getting it there!  atleast that how i feel about it!
« Reply #3 on: December 21, 2008, 05:13:14 PM »
Everything I've ever heard about type 2 automatic trannys has been positive . . . as long as you keep the ATF in tranny and the gear lube in the differential.  Anthony took a manual out of his 76 Westy and put an automatic in it.  He towed his formula V race car with it for a while and if he ever had a problem, I never hear him mention it.
« Reply #4 on: December 21, 2008, 05:16:45 PM »
Good advice,  i'll check this camper thing out and let you know.  SC
« Reply #5 on: December 22, 2008, 08:46:57 AM »
Although mine is still being resto'ed, My 3 speed shifts good and I think I'll like not having to shift in traffic....
« Reply #6 on: January 02, 2009, 10:36:12 AM »
-? Did you get it?
-If not, will you let me know where it is... :D
« Reply #7 on: January 02, 2009, 01:53:26 PM »
I spoke with the owner and said I did not want an auto.  Now I'm kinda into it if the price is right.   I will check with her at work on Monday ,  I lost the number
