Topic: Help with Slow Starter  (Read 232913 times)
« Reply #330 on: February 26, 2006, 02:10:34 PM »
Ok.. so it was a close call with the fire and my plastic gas can.  I decided to see if I can put the metal tank in.  I thought about the gas line I ran down the right rail of the car, swagged under the tranny,  over the axle and to the fuel pump.  The possible reprocutions of a crash or the line catching on a dead dog and exploding , propelled me to reconsider my design..   I cut a brake cable off my kids 10 speed and used the cable to see if I could break the gunk out of the original gas line.
This did not go as smooth as i had hoped
First,  I had to jack the car up,  while i scissor jacked the front of the car up,  the bug rolled backwards,  rolling the jack over to the ground and bending  the screw shaft that make the jack work..  I decided to put it it gear and chuck the wheels .  With my 2nd jack, I un-pinned the first jack.
The first (now bent) jack still operates,  it just is harder to crank.  I got the car up in the air and shoved the ramps under the front wheels ( since the battery is dead and I could not get it started).  I tooked the 10 speed cable, and stuck it in the fuel line by the front wheels,  after about 30 seconds, I broke thru the tar.  I can't believe it.  I guess all the carb cleaner soaking in there for 5 months loosened it up.  A Miracle of modern chemistry.  Now I had to connect the back end of the line that goes to the engine.
I took a scissor jack and started cranking up at the jack mount on the driver side.  I had the left back and left front tire up in the air with the right front tire on a ramp. The car started sliding again, only this time forward.  Gravity.  always working against me..  with my scissor jack leaning dangerously and the bug about to rolloff the wrong end of the ramp,  I began pushing the car back from the right back fender.  With my free hand I threw pebbles at the TV room window to distract an Xbox player to come to my assistance.   Soon my rescue'ers arrived.  ( I guess the match ended).  With the help of teenage angst,  they pushed the stuporbeetle  and jack back to verticle..   Now the car was lowered and bricked etc,  hooked up the line.  gas flowed,  all is well,  engine started.
Whew... close call. I need a beer.  SC
« Reply #331 on: February 26, 2006, 09:23:22 PM »
OK, now that you've got fuel flowing through the correct pipe from front to back, you are well on your way! . . . Well on your way to STILL starting a fire.  I'm not in a typing mood . . . so just click on the link below and read Part Six of Bob Hoover’s TULZ (tools) series:
http://groups.google.com/group/rec.autos.makers.vw.aircooled/msg/756a4a442e3c0996?output=gplain
Pay particular attention to his “bulkhead” or “pass through” fitting.  THIS should be right up your alley . . . It requires going to the electrical section of the hardware store to buy stuff to use on your fuel line!   :lol:
As for you jacking, blocking, ramping, choking, etc. techniques . . . Surely you haven’t been peeping through my privacy fence and watching how I do it have you?  That’s why I put the fence up . . . to keep folks from picking up any of my bad habits.  Just because you’ve seen someone do it, doesn’t make it right!  We need to speak in person about proper use of a jack, ramps, and jack stands (and why concrete blocks and logs shouldn't be used to suspend a car above the ground).  I'd have carpel tunnel by the time I tried to straighten you out using typed text!   :lol:
« Reply #332 on: February 27, 2006, 07:41:39 PM »
That was a good article about how gas will make a fire,  thats why I keep a milk jug full on water in my car.    Bob Hoover talked about how the metal line goes thru the bulkhead in the fan housing.  My fuel line has a 1-2mm hack saw cut right where the fuel pipe rests against the fan tin.  I just pulled the cut part out of the tin so un-cut pipe can rub against the tin.  I can't think of anything around the house that I can use to replace this pipe with.  Fish tank house probaly won't last and gas makes the plastic hose real hard and brittle.   I probaly have to spend more money and  go get a brake line at Advance and make a new bulk head pipe unless you have a better idea.
Aircooled online did not seem to have front flex brake hose for a 71 Stupor beetle. Whats the name of another good online store?    SC
« Reply #333 on: February 27, 2006, 09:58:55 PM »
We also need to talk in person about fighting gas fires with water.  Bottom line is water ain't the best thing to fight a gas fire with.
Try California Import Parts @ http://www.cip1.com
« Reply #334 on: March 04, 2006, 07:27:26 PM »
Zen, I like to use an oily towel to squash out gas fires.  I use the water for
electrical fires.
I stuck the tank in today ,  all the stock gas hoses were cracked so I got heater hose for the big one that goes from the filler tube to the tank.  It will last a while but i need to order some correct gas hose.  I ran the the engine for a while an then it cut out.  Then it started and cut out,  then it cut out.. what the heck?  no gas.  the gas Tank is plugged up.  so I pulled the hose from under the front wheels.  no gas poured all over me.  I blew into the hose... Nothing,  it is backed up like a old man after a cheese and cracker party.
 Now the tank has 4-8 gallons in it and I have to man handle it out of the truck,  Frank helped, but he was smoking, so I was a little nervous.  We poured the gas back into my nifty red plastic gas can,  filled up all my vehicals,  poured some more,  then poured some on a leaf pile and had a big fire, ah fire, i love it
I have the tank sideways and I'm pouring solvent in to the gas exit fitting.
I'm ram rodding it with ten speed cable, wd40,  carb cleane, r3an1 oil,.  what exactly is going on inside the pipe that gas goes out of.  I seems like I'm hitting a wall. I am furious, I am mad, i am drinking a beer.  SC
« Reply #335 on: March 04, 2006, 10:31:13 PM »
The pipe on the bottom of the tank should have a filter screen on the end up in the tank.  Take the big nut loose and the pipe should pull right out.
I'll probably get called down for this, but I'd just remove the screen and put an in-line filter in the CORRECT fuel hose between the tank and the pipe going into the tunnel.
« Reply #336 on: March 05, 2006, 07:14:50 PM »
Zen, you are right on the money.  I took off the gas tank drain plug.  then spent 10 minutes trying to unscrew the mesh filter with a 12mm socket.   that did not work too well , so I took some needle nose plyers and it pulled off.  I took some wire and poked thru the tar in the tube and then chisled the tar and washed off the mess on the mesh filter.  Threw the tank back in and Rock-n-Roll.,\  I am in bizness.  I ordered some front flex lines so I am getting closer to lift off.     My daugter is painting black circles on red bug.  I can't wait to drive the lady bug.  SC
« Reply #337 on: March 13, 2006, 08:57:48 PM »
I got the new flex lines installed on the front brake, in the process, I  wallered and rounded out all the nipple and brake line nuts.  Maybe I should try metric wrenches? I had to buy a new vicegrip wrench,  (I must of wore my old vice grips out because they just could not grip). I re-bled the brakes like a stuck pig.  I still got no satisfaction.  The pedal goes about to the floor then you pump it once and it feels like a pedal should after a couple pumps.  Whats the Verdict?  Should I put in a Master Cylinder? Install 4 Disc brakes, or buy a anchor?  SC
« Reply #338 on: March 14, 2006, 12:26:01 AM »
Jezzzzzz !!!   Sounds like its a little late for metric wrench school. I take it you do have someone doing the "pedal thing" while you are stripping bolt/nuts to bleed the system.
    You have 3 shots to do this right before I get the Rocks and old Dasher parts out.
   1--- Adjust all brakes up
   2--- Bleed  the right front brake
   3----Bleed the left front brake
   4----Bleed the right rear brake
   5----Bleed the left rear brake
Let me know if this works. There are a few other things if it doesn't , but I don't want to put to much on you at one time :lol:
« Reply #339 on: March 14, 2006, 06:33:00 PM »
Bugtech  lests see...
1--- Adjust all brakes up ...Ok I did this.  this means to me, turn the little spinny spur things in the drum holes,  I'm sure I can do this again, but I think I did an OK job with this
2--- Bleed the right front brake...... been there
3----Bleed the left front brake ..........done that
4----Bleed the right rear brake . ... lots of fun
5----Bleed the left rear brake .  ya
would doing the right back left back right front, left front make any difference at all?
I would say I have done this 3-4 times,  I buy brake fluid by the case now,   Whats the next idea'r..  SC
« Reply #340 on: March 14, 2006, 07:47:27 PM »
Ass-back'ards will not do anything to help. Bleed like l told you. Are you getting any fluid out under pressure ?  If not ,you may have a bad master cly, but I'm not there so I'm not sure.
« Reply #341 on: March 14, 2006, 08:04:06 PM »
Well it sprays out pretty good when I don't have the fishtank hose to it goin into a jar.  So yes it has pressure,.  DO you think its a mast cyl?  I can get one for 20 bucks. sc
« Reply #342 on: March 14, 2006, 11:14:53 PM »
Quote from: "Smelly_Cat"
True, you can get a brand spankin' new one for $20.  But if you already have a bad one, why would you want to spend $20 on a new bad one?  The brake crap made in China and India is just that . . . crap.
I'll pull the rings off the Dasher pistons that David throws at me and put them on mismatched worn out 1500 pistons and put them in warped and worn 1600 cylinders, and stick 'em between a way past worn out bottom end and cracked heads, but I'm not going to pay good money for a master cylinder or wheel cylinder made in China or India.  I've used wheel cylinders from India and a master cylinder from China before . . . if they worked at all (which was not an impressive percentage of the time) they didn't work long.
A "GOOD" master cylinder is going to cost you more than $20.  If you decide to use a $20 master cylinder anyway, you need to:
a) Make sure your e-brake functions properly
b) Buckle up
c) Drive SLOW
d) Pray each time you start to press the brake pedal
e) Up your life insurance
 :wink:
« Reply #343 on: March 15, 2006, 10:04:27 AM »
Zen, You forgot :
      F)  Lasso W/Noose to thow at fence post
      G) " Do Not follow me anywhere
   I have a master cly. I will give you. Of course its a rusted mass of metal, Two steel lines broken off flush, Totaly Locked up and one mounting lug broken off. It now has a lovely patina look. This all happened when the car burned to the ground after the plastic gas jug/tank melted do to the short in the Ing.switch.
   I heard a rumour that there is a hole knocked though "The Great Wall Of China" when a Bug driven by a constipated Chinese Dude named "Hung Chow"  couldn't stop due to his $20 master cly.
« Reply #344 on: March 15, 2006, 01:00:13 PM »
You guys are such safety sticklers.  Bugtech,  I will rebleed in the manner in which you directed.  I saw on line that you should put a piece of wood behind the pedal so that you dont bottom out the master cly when you bleed the or something.  have you ever heard of that?  SC
