Topic: Help with gland nut  (Read 6922 times)
Re: Help with gland nut
« Reply #15 on: July 15, 2010, 12:05:42 PM »
Seriously, though, have you tried heat? Propane torch? PB Blaster (almost typed BP Blaster-that's a different problem entirely)?
« Reply #16 on: July 15, 2010, 04:02:13 PM »
Get in touch with Kyle and see if he'll hit it with his 1" drive impact.  SOMETHING will spin . . . it may be you or the engine, but something will give.
Offline attack chicken
  • Ooltewah
« Reply #17 on: July 15, 2010, 06:26:06 PM »
You can swing it by the shop and we will give it a try for ya...I got a new impact the other day that is supposed to be around 1200 ft lbs...It may work. ;D  Sometimes though, the gun is strong enough it's holding everything else still thats the problem.
« Reply #18 on: July 16, 2010, 08:15:51 AM »
  be careful using heat and pb blaster worked with a tech who did that and got the fumes in his eye and it paralized his eye lid for about a week and he couldn't close his eye, not fun
« Reply #19 on: July 16, 2010, 08:39:09 AM »
I'll bring it by someone's shop before too long... But for now, I'm gonna have to sideline everything. I'm getting married tomorrow. I'll try to get it taken care of before the beginning of august. I'm certain it can come loose somehow
  • Trapped in a salad.
  • Aircooled Necromancer
« Reply #20 on: July 17, 2010, 10:13:42 PM »
Happy marriage day!
« Reply #21 on: July 18, 2010, 12:30:16 PM »
« Reply #22 on: July 27, 2010, 11:03:34 AM »
Whew! I survived that part, now we just have to live together for the rest of our lives :o I have recently noticed some perks though. Most notably is the fact that she an now run parts around for me  ;D I placed the tough gland nut engine in the back of my dads truck (she still  has trouble with my manual truck) and if I can't get to it quickly, she has days off so she can run it to a shop to see if they can knock it off. This marriage thing might be alright after all
« Reply #23 on: July 27, 2010, 02:11:16 PM »
Congratulations Nick!
« Reply #24 on: August 04, 2010, 02:28:53 PM »
Happy day! Finally got the gland nut loose! After almost a month! I took it by R and M and rick popped it right off with that new impact. It took maybe 4 seconds, literally. I'm super happy. Now I just have to piece it all back together and bolt it in.
I already removed the broken stud and have another to go back in. Lets hope it all goes smoothly
thanks again Rick K!
« Reply #25 on: August 05, 2010, 09:13:55 AM »
Thats good news.  Goes to show you what you can do with big wrenches and lots of air ;D ;D
« Reply #26 on: August 05, 2010, 12:53:41 PM »
He certainly made it look easy.
The hard part was getting it out of the truck by myself without that jack you've got. I got to thinking... WWSCD? push the baja around towards the porch swing. Remove Porch swing. install a block. put the baja in gear...Nope, kept rolling (engine was in the truck). 4 bricks block tires. Winch out. Put truck on porch. Winch in. Drive truck away. Winch out til engine on motorcycle jack.
Now I just have to torque everything down and throw it back in... I hope the clutch chatter is gone.
« Reply #27 on: August 05, 2010, 03:21:07 PM »
You are a brave man. If I did that the whole dang overhang would be on top me.  By the way ,what is the tire size on the front tires on the Baja ?   The rims look stock.  That is the tire that I want to put on my Type-82e (Reinhart) if they are't to big
« Reply #28 on: August 05, 2010, 04:34:59 PM »
they are from Coker. They are the 7.00 x 15s NDTs or something. It was the only military 700 x 15s they had in stock.
they kinda fit... The rubbed alot until I spaced them out 1'' each. Now they only rub at full turn. It's not bad and would benefit from a lift. If you get yours set up, we can bolt them on to try the fit...if I still have the baja by then
btw they are tubed tires and tough to balance
« Reply #29 on: August 05, 2010, 04:47:55 PM »
NDCCs, not NDTs. NDCCs have the rounded edges, NDTs are squared off.
