Topic: help me Honda Help help me Honda  (Read 8295 times)
« Reply #30 on: May 07, 2009, 07:50:49 PM »
Quote from: "Smelly_Cat"
Zen,  I never changed a motor before so I m kinda chicken,   Im kinda thinking on doing the head gaskt myself.
I've done both on my mother-in-law's Mercury Tracer . . . Changing the engine was EASIER AND CHEAPER than changing the head gasket with the engine still in the car.  I have a cherry picker you can use.
« Reply #31 on: May 08, 2009, 09:05:48 PM »
im going to put a can of super head fixer in crapie honda this weekend
« Reply #32 on: May 08, 2009, 10:08:16 PM »
Good luck with that,  you have been warned!
Offline Bugthug
« Reply #33 on: May 08, 2009, 10:35:35 PM »
I think this "Super Head Fixer" decision was made by your hickified hay-seed alter ego (Futon). You/Futon must have eaten a bad possum!
J.E. Temple
« Reply #34 on: May 08, 2009, 10:52:40 PM »
WASTE OF MONEY....WILL NOT WORK.
« Reply #35 on: May 09, 2009, 02:27:45 AM »
After that doesn't work, remember, I have a cherry picker . . . changing an engine isn't as hard as you think.  It just takes time.   :wink:
« Reply #36 on: May 09, 2009, 05:52:53 AM »
Ok I found just the head gasket for $50 bucks,
From the looks of things I leave the intake manifold connected  so a full gasket set is wastfull
Get the head checked and smoothed.  Waste a  couple weekends.  vroom zoom.
« Reply #37 on: May 09, 2009, 06:57:42 AM »
I have been using roberts and sons machine shop on 58 hwy, they have treated me right, this may be to far for you though.
« Reply #38 on: May 09, 2009, 09:08:41 AM »
Quote from: "travisyoung"
X2... these guys have been a pleasure to deal with... drop a name or two, tell them several guys from VW reccomended you go there....
« Reply #39 on: May 09, 2009, 10:46:07 AM »
Neato  ill try em.
Strange,  I started up the honda to park it out of the way,  and it ran ok  not surging.   so I filled up the radiator  and it still ran ok no surging no bubbles.
Wacky,  Maybe all the stop leak sealed things up, I added a half can of bars leak  just for kicks.  Honda ran for a 30 minutes then the radiator started  peeing out a a pin hole under the  front bumper on my leg.
I filled an old 6 gallon gas tank with water,  I'm gonna have the kid drive it around with the radiator cap loose.
