Topic: heater blow holes in fan housing  (Read 2823 times)
Offline 73boobjob
  • hixson
« on: May 20, 2011, 12:37:30 PM »
i took off heater boxers so should i pulg up the holes in the housing are just letum blow.what's best?
Re: heater blow holes in fan housing
« Reply #1 on: May 20, 2011, 01:21:02 PM »
Why did  you take the heater boxes off ?  You will be looking for them next winter. Every little bit counts in the heat department  ;D ;D  BLOCK THE OUTLETS OFF AT THE FAN HOUSING . NO RAGS NO DUCT TAPE  Unless you sign a contract with me to rebuild you engine when it melts down. :o  Those ports in the housing are outlets not returns.
If left open about 60% or more of your cooling air blows outdoors and not over the Cyl.'s . Not a Good thing.
« Last Edit: May 20, 2011, 01:23:46 PM by Ret.Bugtech »
« Reply #2 on: May 20, 2011, 10:05:15 PM »
It also helps with the cooling if you cover the holes in the tin where the fresh air hoses went through.  If left open, hot air off the bottom of the engine will be sucked back into the upper engine compartment and that pre-heated air will be pulled back into the cooling system.   ;)
Offline 73boobjob
  • hixson
« Reply #3 on: May 21, 2011, 11:54:05 AM »
now iknow ,Thanks-a-lot
