Topic: Headlight Question.  (Read 3516 times)
Offline Roadkill
  • Ooltewah Tn.
Headlight Question.
« on: December 29, 2010, 11:56:34 PM »
I have noticed that my headlights are " yellowish " ( weak ) in regular mode and fine in high beams. I have read the other post of weak headlights here in the tech forums but wondered if there is a difference between the 6 volt system he has a 12 volt system i have on the possible problem or if headlights can go " weak " in regular mode and still be good in high beams. Thanks for any info as i have 3 days off this weekend to check things out. ...........
Re: Headlight Question.
« Reply #1 on: December 30, 2010, 12:56:14 PM »
It sounds like corroded connections somewhere.
It's been a while since I worked on a Beetle's lights, but I'm thinking that the brights and dim are wired through different fuses.  When I got my Dasher from Rick, about half the lights didn't work.  I started messing with the fuses to see if any were blown and the more I wiggled 'em around, the more lights came on and the brigher they got.  I finally took all the fuses out, brushed the connectors with a small brass brush and istalled new fuses . . . and the radio even came on.
If you do find it's a bad connection somewhere, a little dab of dielectric grease on the connection after you've cleaned it up will give you several extra years of corrosion resistance vs. just plugging the clean connection back together.
« Reply #2 on: December 30, 2010, 02:45:21 PM »
I've heard that the pink eraser on the good ol' #2 will clean the little terminals up nicely!
« Reply #3 on: December 30, 2010, 02:56:08 PM »
Once you've cleaned up all the corrosion, consider an upgrade to H4 housings and bulbs. They are much brighter than the sealed beam halogens.
« Reply #4 on: December 30, 2010, 08:57:07 PM »
I just put H4's in the Jap Beetle, COOL!
They also have the parking lights in the housings.
This is a big plus in that the Jap beetle has no other parking lights in the front...
Offline Roadkill
  • Ooltewah Tn.
« Reply #5 on: December 30, 2010, 11:41:42 PM »
thanks for the info guys. Alot of what you have said is what was going through my head. I will start looking at the connections.
Offline Roadkill
  • Ooltewah Tn.
« Reply #6 on: December 31, 2010, 12:30:52 PM »
well i took the headlights out and cleaned the contacts there. put it all back together and still the same result as before. will move on to other contacts now. However now i can not get the passenger side headlight ring back on. It is like it is too small or some reason. I really need too learn to leave things alone like the Godfather has told me...  ;D
